Question about Frigidaire Washing Machines
Frigidaire Front Loader LTF2940ES3 does not fill.
I had to call a service man and he said that it was the Speed Motor that had to be replaced.
Posted on Jul 04, 2009
How to reset a Frigidaire front load washer Model LTF2940ES3
Empty the machine. Turn off. Close door. Try pushing simultaneously 2 buttons at a time while powering up. This would reset the machine.
Jan 12, 2014 | Washing Machines
Change control board on Frigidaire washer LTF2940ES3
This is typically not a DIY type of job since the entire front, top, panel where the settings are needs to be taken apart to reach the control board and wiring harnesses.
Jul 19, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire lft6700fso washer not filling with water
water pump is clogged i pulled it out and cleand it and put it back and its working like it should and the part n is m222-5 on the frigidaire front loader
Mar 12, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire LTF2940ES3 Erro 21
ok take the bottom panel off theres two screws,,almost to each corner,,,always unplug first...ok check your pump its on the left and has two black hose,,clean and,,reverse to put together...onthejob..the top panel with door cant be removed
Jan 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Front end washer lights come on but doesn't fill.
it fell out of the dispenser, hold the dispenser facing away from you on the left side there is a small slot, place the magnet in vertically so the long side of the magnet is on the right when looking from the front with the drawer closed good luck
Dec 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Fill ing a front loader
the max wight will be given in your book - usually about 5kg
Jul 09, 2008 | Frigidaire ATF6000ES Front Load Washer
E10 error with NEW front loader fridgidaire
Are you sure that water fills the tub ? Close the hot water tap and check if cold water fills in, then close the cold water tap and open the hot water one and check whether hot water fills in. Let me knw with your test results.
Aug 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
153 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
