Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
What could be wrong with my 18cu.ft. top freezer refigerator if only the top cools not the bottom
aasc
  • 1606 Answers
SOURCE: have a whirlpool refigerator. Model ET8BPKXKZOO.
The overload/relay which pluggs onto the side of the compressor is bad . Pt # 2262181
Posted on Aug 07, 2009
mgprice
  • 744 Answers
SOURCE: freezer has alot of frost build up and the
Hi, this sounds like a problem with a blocked defrost drain. For full instructions on clearing the drain from my tips click HERE . If you have any other questions please feel free to comment. Mike
Posted on Dec 21, 2009
heatman101
  • 43501 Answers
SOURCE: My top freezer is not cooling, but the
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 20, 2010
imufo2
  • 3773 Answers
SOURCE: I have a whirlpool arc4170 fridge/freezer. The
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 06, 2011
  • 227 Answers
SOURCE: whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Posted on Jan 01, 2012
Light came back on in older 18cu.ft. Frigidaire (freezer on top) refrigerator after lightening storm tripped a GFI plug on the circuit but no cooling or freezing No sound of motor running.
As the light works the supply is obviously ok.
It would seem to be time to find the reset button if there is one and try pushing that. If no reset button or it doesn't work the circuit and supply will need tracing through with a meter and/or a test lamp in order to discover the fault.
Apr 29, 2016 | Frigidaire Refrigerators
Bottom freezer works, top refigerator does not get cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Refrigerators
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
I lost colling in freezer then in refigerator . I unplugged and then replugged in didnt work I also have not recently moved.
heatman101
Feb 23, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Refigerator has no cold air freezer works good
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 21, 2010 | Amana AFI2538A Bottom Freezer French Door...
Bottom freezer works top isn't cooling and noisy
heatman101
Nov 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer -24 F and refigerator will not go below 58F
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Unit was making noise. bottom freezing, top meling, no cold air blowing into the refigerator from freezer
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | Amana Refrigerators
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Refrigerators Logo
21 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
