Question about Health & Beauty
I need a tanning bed manual for a wollf 424sl
How does the acrylic lens come off so you can get to the bulbs to replace and clean them?
2 Suggested Answers
Gophering
  • 187 Answers
SOURCE: i need a manual for a sunual 3200 tanning bed ,i
Try this link...
www.freemanualsonline.com
Kind regards!
Posted on Sep 13, 2011
How do I replace the retaining trim on a sunvision pro 28 lx tanning bed?
Silicone it back in place. Use tape to hold it, let it set for 24 hours.
Mar 18, 2016 | Cars & Trucks
How to replace bulbs in tanning bed
Without the specifics of your bed, I can give you some general info.
  • The first thing you need to do is remove the acrylic. Depending what type of bed you have, this may require a screw driver to remove the metal retaining strip on the outside edge of the acrylic.
  • Set the acrylic aside, & remove the burnt out bulb(s).
  • Depending on the type of bulbs you are using, you may need to place adapters on each end (these can be removed & reused from your old burnt out bulbs).
  • Regardless of bed type, most have one thing in common when it comes to bulb terminals. One end of the bed will have a stationary terminal, & one end will have a springy one.
  • Place one bulb end in the spring side first, press in, & guide the other end into the stationary side.
  • Turn bed on for a test to make sure everything is working properly.
  • Replace acrylic (and retaining strip if necessary), and you're ready to tan :)
Jan 06, 2015 | Health & Beauty
How do you get the glass off to replace bulbs
First, just pop off the colored strip along the entire canopy; mine is a burgundy looking color. This is just pressed into the groove on the flat side that is on the bottom of the strip on the top canopy. You can sometimes get it off with your fingers, but might need to get it started first with a flat head screwdriver. One you start getting it to lift up, the rest pulls off very easily. Then the metal piece on the side will just pop down or up (can't remember which) and then you can remove the curved acrylic by just putting a hand on each side and pulling it out towards you; It is not heavy, but it is big and bulky so it is easier with 2 people but can be done with just one person. I am female and I have removed mine several time by myself. My husband and I just recently replaced all of the bulbs in mine, facial tanner included. Good Luck. It really is easy once you know the tricks. Also, you can download the manual at http://www.docstoc.com/docs/87389135/Sunvision-Pro-24S-Tanning-Manualpdf---WolffTanningBedcom. Sunvision Pro 24S Tanning Manual pdf WolffTanningBed com . Good Luck!!!
Jul 12, 2014 | Wolff Sunvision Pro 24S Tanning Bed
Sunvision facial tanning bulb buzzing and flicker's and won't light
It is not the socket. If the bulb is installed correctly, there is a starter on the ballast that needs to be replaced.
May 07, 2014 | Wolff Sunvision Pro 24S Tanning Bed
Tanning bed manual
http://tanning-bed-parts.com/documents/ETS%20Tan%20Documentation/Manuals/22680.pdf
I was able to find you a PDF Manual for the tanning bed model you listed, the key to looking for it online was to enter Wolff Sunvision Tanning bed......without the Wolff part it didn't come up.
Hope this helps and good luck!
Apr 28, 2014 | Health & Beauty
2 tanning bulbsdont work. could it be the fuse in the bed
maybe they burnt out. you can use an UV reader, which lets you know when to replace the bulbs. it tells you how much UV light is being outputted. When you replace your tanning lamps, it is ideal to replace them all at once.
look here for more info http://www.mastertanning.com/tips/23/tanning-lamps/
Feb 26, 2013 | Health & Beauty
Do I need to worry about how often salons change the bulbs in their tanning beds?
Yes - even though in theory tanning bulbs can last up to 1,000 hours, if they are not changed very regularly, they can seriously affect the quality of your tan. Bulbs should be replaced after 500 - 600 hours use.
Feb 18, 2013 | Health & Beauty
Health & Beauty Logo
24 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
