Question about Realspace Pro 3000 Series Custom Fit Mid-Back Fabric Chair, 40 1/2in.H x 25 1/4in.W x 22in.D, Black/Black
How do I get my arm rests to stop sliding forward and backwards?
RCA VLP37H needle arm won't advance to play record...moves backward, then seats down again
You will probably have to take the bottom off to see what is happening inside. The thing could have been tampered with by someone try to fix something. So it's not something that you know was previously working. With a bit of luck it might need a bit of grease to get it going. But you never know with a second hand model!
Aug 17, 2014 | Audio Players & Recorders
Arm rest turned sideways
Sit down. Grab the front of the arm rest & pull backwards.
Feb 21, 2014 | Ergogenesis BodyBilt J2507 High-Back...
How much forward and backward slop should there be on the mainshaft 1st gear when i turn it back then forward on the clutch side
When you've got the clutch off and you're turning the mainshaft by hand backwards and forwards, it feels like a lot. I've never measured it but it seems like it's about a half turn or so. What you are doing when you turn the mainshaft backwards and forwards with the transmission in gear is you're moving the dogs of the first gear clutch dog in the transmission back and forth in the slots that it the dogs fit into. They have to have enough room to slide into the slots but when it the engine is running. the dogs go all the way to the backside and stop. Unless you're having a problem with the transmission, don't worry about this back and forward movement.
Good Luck
Steve
Jun 17, 2011 | 2003 Harley Davidson FXD Dyna Super Glide
860 slide projector does not move carosil forward or backward and does not respond to selecting slides, but manual on projector will actuate slides but will not move carosel forward or backward. thanks
there is a small rubber link inside the projector that controls the advance this part fails in time and would cause this problem. the part is not hard to recreate but is difficult to replace.
Jan 16, 2011 | Office Equipment & Supplies
Loud clicking noise on startup
Had the same problem with machine gun noises. Solved same. Simply turn printer off. Open door. With a flashlite, look inside to the right side where you'll see a small tray that slides forward and backwards. This is the cartridge cleaner. Push the tray forward (away from you) until it stops then move it backwards until the little black tab on the right is 1/2 inch from the metal part of the carriage. Close the door. Turn printer on. All done. Print something.
Oct 28, 2010 | HP D1660 InkJet Printer
Ekatagraphic slide projector that won't advance the carosel forward or backward. it will pop a slide up and down. it sounds jammed it humms when buttons are depressed any ideas?
The most common causefor the failure of the slide tray to advance or reverse is the breakageof this small Link (part # 217769). It fits on the end of the solenoid actuator arm and is held in place by a Rivet (part # 159943). Thereplacement of this part does not take a rocket scientist, however, amoderate mechnical aptitude skill is required.
This Set contains 1 Link and 1 Rivet. If your projector Does NOT have a focus motor in it, then this is the kit for you. If your projector does have a focus motor, please order "KODAK-KIT" From: https://www.micro-tools.com/store/item_detail.aspx?ItemCode=LINK
Apr 24, 2009 | Office Equipment & Supplies
Need to remove door panel to repair window that is off track
There is a spring clip that holds your window crank on. Your best bet is to get a window crank remover. You can get one at most automotive parts stores. They're only a couple of bucks. You shove it in behind the crank, and then turn the crank, and it'll pop the clip off. When you re-install it, put the clip on the handle, line it up where you want it to be when the window is closed, and give it a bang with your hand. It should pop back on.
The arm rest will most likely be held with a couple of large philip's head screws. They are usually on the bottom side of the arm rest, sometimes the top, sometimes hidden by nylon plugs. Some vehicles only have one screw, and then you slide the arm rest forward to remove it.
I'm sure you'll figure it out once you start looking. Good luck!
Apr 03, 2009 | 1994 Toyota Pickup
Mini one
Door panels should be 4 T-30 screws. one is behind the door reflector. just pry this out with a screw driver. then the other two are 2/3's the way twards the inside of the door. then the last one is inder the arm rest get a dull butter knife and slide the knife in the middle of the arm rest between the armrest and door handle. the armrest should slide forward toward the knife. Apply some force do not pull out slide forward. then remove the last screw from behind the armrest and remove the door panel. Just door panel clips remain. Grab the panel and pull it will just pop pff.
Feb 24, 2009 | 2002 Mini Cooper
Door panel removal
  There is hidden screw under top of arm rest.  the mirror control comes out.  Be careful.  then there are 2 screws in bottom of arm rest.  Then the arm rest/handle needs to spin up towards sky and it will pull out.  the scushing (plastic around handle ) slides forward and this handle surround will come off.  Then there are clips that are behind panel.  Put hand between door and door panel and pull panel outward. be careful.  sometimes firm tug is better
Jan 01, 2009 | 2001 BMW 325
Orbit walking sprinkler
You probably just have the arms pointed the wrong way. To travel forward the angled part of the arm should be pointed in a clockwise direction. Aim them the other way and it travels backward.
Aug 25, 2008 | Electrical Supplies
Realspace Pro 3000 Series Custom Fit Mid-Back Fabric Chair, 40 1/2in.H x 25 1/4in.W x 22in.D, Black/Black Logo
62 people viewed this question
Top Realspace Pro Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Realspace Pro Furniture Expert? Answer questions, earn points and help others
