Question about Talaris EV8650
LID CLOSED STILL SHOP LID AS AN ERROR
Error LID
  • 343 Answers
Looking from the back of the 8650 counter with the lid open, there is a safety switch on the left side. It is either not pressed in when the lid is closed or it is broken. To test, take the two wires from that switch and connect them together. That will by pass the switch and allow the machine to work. Good luck.
Posted on Nov 26, 2014
Help with "Lid" error on Kenmore Laundry center (washer half of a stackable)
Occasionally some folks who live way out in the country really need the washing machine but have no access to repair parts, so here is a "trick" that might temporarily solve your problem.
The lid switch is often rectangular, and has a wire that plugs in to each end of it.
With the machine unplugged, remove the wires from the switch and plug them in to each other, then wrap them well with electrical tape. Fasten them in such a way that they will not touch the drum or other parts, and then try the machine.
You have "told" the machine the lid is closed.
Of course, now the machine is DANGEROUS to use because when you lift the lid, it will continue to run through it's cycle.
God bless your efforts.
Aug 23, 2015 | Kenmore Washing Machines
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
Hp Laserjet cp4525 50.2 fuser error
What helped me was this: when you close the fuser cover, there are two white tabs that lock the paper feed assembly in. Well, the tab on the left tends to slip off if not closed correctly. Try closing the lid slowly putting more pressure on the left side of the lid. What happens is when the tab slips off, the paper never reaches the fuser and the printer throws the fuser 50.2 error.
Jul 20, 2012 | Office Equipment & Supplies
Error message dE
hello there and thank you for choosing fixya
dE - Lid door open error Lid /door isnt fully closing or is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board
Jul 28, 2011 | GE Energy Star WCVH6260F Front Load Washer
I have a top load machine which shows LE error code despite lid is closed properly. This continues for half an hour then machine starts working again but the error resumes after every two minutes. Plz help
'LE' stands for Lock/Lid Error. There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 22, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Why does it say "op" when i press the start button?
The Service Manual for reference. Sears Parts Direct for reference.
I feel you have lost signaling from the Left Hand Lid Lock for Lid is Open/ Lid is Closed.
First check is to place a magnet over the Left Hand grey bumper and while watching the LED display see if the OP error code clears. If it does you have a lid magnet out of position. See the Service Manual for access to the Lid Magnet.
See Pic;
If an external magnet over the Left Hand grey bumper doesn’t clear the OP error code with the lid open then See this Link for troubleshooting Left Hand Lid Lock Troubleshooting. I discuss the OD error code but the OP error code troubleshooting is very similar. If the lid Magnet is not out of position then I feel you have a broken lead at the Magnetic Reed relay or severe corrosion issues with the Left Hand Lid Lock preventing Lid Open/Lid Closed status signaling to the Control Board in the Console.
FAV6800A/FAV9800A replacement Left Hand Washing Machine Lid Lock - 25001048
Let me know if you have any questions or concerns…….Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Od error code
I've been fighting the same problem for 2 days in frustration I just dropped the lid and it started working
Mar 31, 2008 | Maytag Neptune FAV6800AW Top Load Washer
E2 error but I did close the door
I think there is a problem with the spring that is attached on the left hinge of the door. Try elevating the door for a couple of milimeters with some rubber object. that should help
Aug 21, 2006 | Haier XQJ50-31 Top Load Washer
Talaris EV8650 Logo
509 people viewed this question
Top Talaris Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Talaris Retail Supply Expert? Answer questions, earn points and help others
