Question about Panasonic Viera Plasma TV TC-P60ST30
Tc-p60st30 red light flashing 7 times - Panasonic Viera Plasma TV TC-P60ST30
4 Suggested Answers
  • 8457 Answers
SOURCE: TC-P42C2 Power Indicator
Power LED light indicator are flashing it is the effect of the power supply board are dying and not giving the tv the wright amount of voltages anymore.That the board,where the power a/c cord plug into it.U have all the tools,u understanding basic electronic also can u do basic soldering?Yes,check all over the power supply board for dying parts call capacitors.These dying capacitors are alway bulges up or puffing up on to it tops.By replacing all these dying capacitors are bulges or puffing up on it tops,will solved this flashing LED power light indication,power supply board will work again.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Jan 07, 2011
DrewPalmer04
  • 325 Answers
SOURCE: I have red light blinking
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)! The backlight inverter is what lites the screen for viewing!
I would recommend to repair immedately and stop trying to turn it on over and over...this will futher damage your tv and cost more to repair in the long-term.
Please rate if this helps! :D
Posted on Mar 10, 2011
dcramer531
  • 1654 Answers
SOURCE: 15 months into owning our
My suggestion is that you get an estimat from a dealer on repair costs and you decide whether you want to spen money on a part or new set. This is a bad circuit board and probably the power supply. The repair will be around $200.00 minimum unless you get lucky and there is no major issues and the board can be repaired.
The service manual says. you have what you call a "shut down circut" it is for safety and when one of the internal boards gets shorted or is not working properly, service doc reads as follows
7 Blinks SOS:
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times
thiera blinking 7 times is cuase by a fualt in sc,su,sd board.
If the board shorted another before it went dead you could have other issues, thats why you need a tech to look at it and give you an estimate. You never know, this being so close to warranty they might work with you on it.
Posted on Mar 23, 2011
My Panasonic TC-P60ST30 will not power on. It makes a click sound but will not power on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 28, 2016 | Panasonic TC P60ST30 60 Class VIERA ST30...
Panasonic 50 inch plasma th 50px80ua tv won't turn on and red light flashes seven times
Hi Steve, The link below is a YouTube video showing a panasonic television with 7 red flashes, Also there's videos down the right side of the link that may help as well... I hope this helps............CHEERS..
Panasonic TC P50S30 review seven led flash
May 01, 2016 | Panasonic Televison & Video
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
Aug 27, 2014 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
Panasonic Viera tc-p60st30 tv will not turn on. No red blinking light. Relay clicks every 10 seconds.
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 14, 2013 | Panasonic Viera Plasma TV TC-P60ST30
Panasonic TC-P50G25 sudenly stopped working the Red light flashes for 7 times and takes a pause, this continues
Its an error code that likely indicates a power supply problem.
Suggest you Google the model number with "7 blinks" "error codes" or "service manual".
May 04, 2012 | Televison & Video
Panasonic Viera Plasma TV TC-P60ST30 Logo
119 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
