Question about GE Deluxe AGM12AB Air Conditioner
Ge window unit
When its switched to cool... the cool light just blinks and the commpressor never turns on...
Check the connection between the starting capacitor and the Start "S" of the compressor it should be connected and also the "cool light" other wire is also connected with it.
Posted on Jun 09, 2011
It stoppped cooling. when i plug it in days later
Check out these tips that I wrote about that...it is a great place to start trouble shooting your unit...and something thatyou can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Kenmore Side by Side Refrigerator
What would cause AC clutch to not engage when ac is turned on 1999 Siverado Z71,It blows air but its hot air even when on max AC someone said that the clutch on commpressor wasnt engaging do you have to...
This could be a few things.
1- Check fuses for A/C
2- Check to make sure the unit has freon
You have a switch on the accumulator that is called a low pressure shut off switch. It prevents the compressor from running when the freon is low. I would suggest if it is not a blown fuse, have a certified A/C repair garage take a look at this.
Aug 25, 2010 | 1999 Chevrolet Silverado 1500
Wirering diagram for pump down system refrigeration
close liquid line small pipe you need gages to do it properly but run the unit on cooling untill you hear the commpressor struggling generaly couple of min depending on pipe length and type of unit cycles then close gas valve bigger pipe switch off power and it shoul be pumped back into outdoor condensing unit
Mar 10, 2010 | Heating & Cooling
Just turned on system (95 degrees here today)...and the fan works fine, but no cold air comes out...just room temp. Worked fine last fall. GE Window unit (10,500 BTU)
You need to determine if the commpressor is running. If it is, your unit need a recharge of refrigrant. If it is not most likely the start capacitor is bad. A $20 fix if you do it yourself.
Stan Marietta, GA
Apr 26, 2009 | Heating & Cooling
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
Cool/AC light is blinking
Try cleaning the filters & coils good with a shop vac, or a scrub brush.
Jun 03, 2008 | GE Deluxe AGM12AB Air Conditioner
Denon AVR-1906 Reciever is not working. Was watching a movie and then it suddenly shut off. Now, the power light is blinking red. When I try to power it on again it starts to boot up but then turns off...
speaker terminal are short circuit,switch power off connect speaker properly then switch power back.
-the ventilation holes of the set are blocked-turn power off and make good ventilation around leave the set to cool and turn power back.
-the unit is operating at continuous high power turn it of and allow for cool down and switch it back.
Jun 01, 2008 | Denon Audio Players & Recorders
Ge profile Refridge...
check if the outside walls and back are hot to warm,. if not warm posible low level gas, or commpressor not pumping gas around.
Oct 18, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
GE Deluxe AGM12AB Air Conditioner Logo
412 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
