My toshiba l40-14n won't charge and will only stay on for about 2 mins when connected to power supply: help?
My laptop won't turn on most of the time. the screen comes on sometimes but loads up a fresh screen as if it's a new computer with none of the saved files. even though it's connected to the mains power supply it still barely stays on for a few minutes which isn't really enough for me to diagnose the problem. I've tried other cables but that doesn't seem to be the problem. I thought possibly it may be a fault with the battery? can anyone help ?
  • Computers & ... Master
  • 928 Answers
There are only three parts from the Toshiba laptop that could be wrong:
1. Power Supply/Charger
2. Damage battery.
3. Electrical input port.
First, troubleshoot the charger, you can try it with another Toshiba laptop of the same model, if it shows that is charging, then then troubleshoot the battery.
To TS the battery, just get a battery from a friend, or if you can go to a store where they sell batteries, take the laptop with you and let them know that you want to test it first.
If the battery is not the problem, then you have a faulty electrical input port.
I had a Toshiba Satellite, also, I'm I.T.
Posted on Jun 26, 2017
  • 2427 Answers
SOURCE: Satellite A100-166 PSAA9E does not charge the battery
Your power controll circuit on the main board is bad, you might need to change that or the entire board itself.. If you can get a technician just to repair the power controll circuit you should be fine. most ppl dont do that cause its difficult. Normally your entire main board is replaced. To fix that i will need to see the board but thats difficult since i am sure you dont live anywhere close to trinidad but i am sure someone close to you will be able to repair it, or your can download your service manual for your laptop and attempt to repair it your self.
Posted on Dec 31, 2007
The_PhoeniX
  • 156 Answers
SOURCE: Laptop won't stay on
it might as well be a internal problem related to power or loose contacts with RAM or the power chords internally.
Better to go to the technician in this case.
Your first Battery would have been fine too..
Posted on Apr 12, 2008
djbr1ck
  • 158 Answers
SOURCE: E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
Posted on May 12, 2011
meinverstand
  • 181 Answers
SOURCE: I have Samsung NP-R505H laptop. My laptop won't
You say it isn't charging, but will it run off of AC power? If it isn't getting *ANY* AC power, then it might be the female end of the power jack on the laptop. If it will run on AC, the culprit is likely to be a battery that needs replaced.
Posted on May 13, 2011
SOURCE: Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Posted on Mar 29, 2012
Problem with Toshiba laptop
It stays on with Battery? Has the AC jack been damaged due to pulling on the cord while plugged in? Have you tried another cord/charger with the EXACT same power specs? Does the cord/charger charge the Battery? Charge LED lights? It sounds like a Graphics Adapter? If you connect to a external monitor is it the same. Your question/statement indicates multiple issues. 1 , Power, 2, Graphics. Can you clarify "color blank"?
May 22, 2013 | Toshiba Satellite PSLD8U-00G001 L355-S7831...
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Rdrhow to find recharge componets on a215-s4807 motherboard?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 14, 2012 | Toshiba Computers & Internet
Screen and system freezes when AC is disconnected, I changed the battery but the problem still. Laptop is a Toshiba satellite l635
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 01, 2012 | Computers & Internet
Toshiba t135 laptop won't turn on
If its not powering on 3 problems could be there the battery/ the power supply or the power management chip or lastly the charge chip around the inside of the laptop inside its self
Jan 10, 2012 | Toshiba Satellite Computers & Internet
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
TOSHIBA dlp projection, model 42hm66 won't stay on
Could be the power supply. You can check the power from supply with multi-tester or voltmeter. If have a service manual, then I suggest testing the ballast as well
Aug 07, 2009 | Toshiba 52HM95 52" HDTV Projection...
Power won't stay on
I hate to tell you this but the most common problem with these laptops is the power connector on the motherboard. It will make contact just long enough to flash then finds there is not enough power getting to the system. Is the connection in the back loose? If so when you wiggle it does the charge light come on? I have made a considerable amount of money on replacing these for people. It is the only thing Toshiba did not get right. In my opinion they are the greatest systems around, just wish they would have made the connectors more secure. Good Luck.
Dec 27, 2008 | Toshiba Satellite A135-S4467 Notebook
My laptop is a toshiba satellite P25-S526. I cant seem to get the power supply to charge the battery. I have replaced both the battery and power supply and those were not the problem. why wont my...
If you have a volt meter measure the power coming out of the power supply and make sure the outlet is good that you are plugging it into.
Try resoldering the connection on the circuit board where the power supply plugs into it. There may be a loose connection or a crack in the board that you could jumper around using a short piece of wire soldered around the break.
Aug 26, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
