Godrej eon washing machine e2 problem.
When washing cloth...its gone to e2 error..
  • Anand Shastri
    Anand Shastri May 21, 2017
    Well, I think it is as simple as - you have not unhooked and brought down the drain tube on the right, so water cannot drain out. Do the following:
    1. Unhook and put the drain tube down so that water can flow out.
    2, The machine will not start automatically.
    3. Put the MAINS power off and then on quickly, and press the START button.
    4. The machine will start from where it stopped.
  • 3,180 Answers
Eco wash fault this can be down to hard water areas, the switch for the water intake is stuck can be opening but not all the way so it shuts it back off and you get this code.
Posted on May 09, 2014
  • 43 Answers
SOURCE: Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Posted on Nov 11, 2008
  • 44 Answers
SOURCE: Error E2
A model number always helps when you're looking for help. ;)
I looked through about twenty manuals looking for an answer for you; I suggest that you'll have better luck if you have the model #.
Here's the link to the many, many, many Daewoo washer manuals.
WashingMachine&cpage=1">http://www.dwe.co.kr/english/support/download.asp?class1=5&class2=19&class3=0&selorderby=1&searchpath=WashingMachine=>WashingMachine&cpage=1
Good Luck!
Posted on Aug 08, 2009
SOURCE: E2 error on homemaker washing machine.
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Posted on Nov 08, 2009
SOURCE: Heller awm600 washing machine e2 error on spin
BROKEN PIECE OF PLASTIC ON LID CAUSING MACHINE TO THINK LID IS OPEN ALL THE TIME. REMOVE LID, WEDGE BROKEN UP SATAY STICK INTO GAP, REPACE LID AND VOILA!! WASHING MACHINE SPINS AND ALL FOR LESS THAN 15 MINUTES WORK AND A STICK!
Posted on Jan 10, 2010
6ylucy
  • 742 Answers
get the manual at manualfox.com
Posted on Jun 18, 2010
When stachi do, not move clothes.
Godrej front load washing machine model no GWI5511 RES. Error e 5
Apr 20, 2017 | Washing Machines
What does it mean when washing machine has F5 and E2 error
If it is a Whirlpool then The F5 E2 alert indicates the washer can't engage the lid lock because there may be an obstruction in the lid lock area.
Please check the lid lock area and remove any objects in that area. Also verify there are no clothing items in the way.
Otherwise, provide the manufacturer name.
You may visit http://producthelp.whirlpool.com/Troubleshooting_Guides/Troubleshooting_for_Top_Load_HE_Washers_(Electronic_Control)/Error_Codes/F%23_E%23_or_F%23%23/F5_E2_Error_code_for_top_load_washers
Feb 04, 2017 | Washing Machines
When washing cloth its gone to e2 error
This usually means the control panel is faulty. Sometimes buttons stick or short out and cause this on the Samsung washers. You may can unplug the washer for a few minutes, this will reset the computer. If it continues, try pressing each button individually to see if one is stuck. Sometimes this makes the button pop out. Have someone check the wiring connections by taking them off one at a time and reinstalling.
Jun 13, 2016 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Show E2-3 from toshiba washing machine aw1190s
can't open the lid to take the clothes out
Nov 19, 2012 | Washing Machines
I recieved the following error code on my gas range with self cleaning oven... error code E2 F1... PLEASE HELP ME
Hi
Thanks for using FixYa. F1-E2 error indicates that the oven is too hot & the oven temperature sensor has gone bad and should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Washing Machines
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Washing Machines Logo
410 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
