Question about Asrock Computers & Internet
Ion video 2 pc
Device is installed but it is unspecified it is undetectable by power director software
SOURCE: JVC ieee 1394 not connect
This is not a solution to a problem.We need solutions not suggestion about a system we are not being able to use.
Posted on Apr 19, 2008
SOURCE: WHERE COULD I DOWNLOAD THE HP DIRECTOR SOFTWARE
Hi go to hp site find utiliity section for this printer
Posted on Sep 12, 2008
  • 1027 Answers
SOURCE: I've just purchased ION Video. 1. It will not
Ion states that the drivers are NOT compatible with Win 7 at this time. Only XP or Vista.
Posted on May 04, 2010
  • 32 Answers
SOURCE: ION Audio VCR 2 PC USB VHS Video to Computer Converter it record
hi, friend, the aHisoft Video Converter is just prepared for you, It is a Total Video Converter that can convert video to MP4/MKV/WMV/AVI and other popular formats such as: AVC, FLV, MP-1, MP-2, 3GP, 3GPP, Mov, M4V, ASF, SWF, VOB, DV, Super VCD, VCD, DVD and HD video.
so i think it will be helpful, you can search it on google
or visit http://www.asharer.com/
Have a nice day, my friend!
Posted on Aug 20, 2010
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
I installed the Ion VCR 2 PC converter and when I clicked VCR 2 PC to record, it says "the device is not avaliable, or is being used by another application" and will not let me use the machine. What do i...
1. Check in your Device Manager whether any Yellow coloured Circle with Black Exclamation is present, if yes then your driver is not installed properly.
2. See whether your device is recognised, If not try uninstalling the device driver and software and unplug the device. Restart the OS (do not connect the device), Install the Software and driver and after completion or if it asks to plug in the device, plug in the device and power on.
3. Still having the problem, check the latest updates or patches if required from the website, if nothing helps try it on another PC or reinstall OS in your PC.
Sep 11, 2010 | ION Audio VCR 2 PC USB VHS Video to...
May 04, 2010 | ION Audio VCR 2 PC USB VHS Video to...
I have Windows XP home\service pack 3 AMD
you may need to install proper codecs for the output format of your camera. use klite codecs(you can find it on the internet for free). try to use vlc or mplayer and see if you have the same problem.
post again if you haven't solved your problem. i'll keep an eye
Jan 26, 2010 | Computers & Internet
How to Turn a Regular Video Camcorder Into a Webcam
Hi, maybe you can try to download a software like Cyberlink Power Director 8. After installing that software, you can connect your Camcorder to your computer then Open the Power director you have installed and go to the "Capture" tab and see for your self.
Hope this helps you..Merry Christmas ( :
Dec 27, 2009 | JVC Everio GZ-MG20 Camcorder
Graphics drivers are not installed in my computer so i need that driver my mothreboard model is p4145Gx_PE pls tell me for downloading that driver
Video Card : Intel Corporation 82845G/GL/GV/GE/PE Integrated Graphics Device
Some other info:
Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 2
Processor : Intel Pentium 4 @ 2800 MHz
Chipset : Intel i845G
Mainboard : Unspecified P4I45Gx_PE,
Manufacturer : Unspecified
Bios : American Megatrends Inc.
Physical Memory : 2048 MB DDR-SDRAM
THERE!!!! http://www.soft32.com/download_173342.html Here are the drivers. hope it works
Aug 02, 2009 | Intel Computers & Internet
Burning of DVD from Power Director V7
LOOK IN TOOLS AND SETTINGS OR HELP AND FIND THE UPDATE BUTTON AND UPDATE THE SOFTWARE. PLUS YOU ARE RIGHT THAT IT MAY BE PROBLEM USING EXTERNAL DRIVE.(IS IT USB 1.0?)..COPY YOUR FILE TO A TEMPORARY FOLDER ON YOUR DESKTOP AND BROWSE TO THAT FOLDER WITH POWER DIRECTOR.
May 28, 2009 | CyberLink POWERDIRECTOR 7 VLICDELUXE for...
The printer will not scann to the computer
Are you able to print? I suspect so. If not your probably looking at a bad cable or corrupt windows drivers.
The director software uses it's own system to talk to the printer via scan / fax though printing is controlled by windows itself. Since scan and fax are the same function to the printer, essentially i would start by re-installing the director software.
1. Remove it via add/remove programs, don't reinstall over. It may work but you'll likely just waste time, you want all it's files gone and replaced with new ones.
2. If that has no effect remove the printer from Control Panel > Printers. Also remove the scanner device from Control Panel > System > Hardware > Device Manager >
3. Reboot, windows doesn't really remove things till you shut it off.
4. Install the director software again, hook up the printer when asked.
Again:
If you can print at all communciation with the device is perfectly fine from a hardware perspective.
If you can fax without the computer then your scanner and such is fine from a hardwware perspective.
So your problem is simple software, either windows devices install or hp director. Both simple to remove and re-input.
It's very
Nov 09, 2007 | HP Photosmart 2710 All-In-One InkJet...
Hp director
It could be about this: I had same problem until I found a review somewhere - even HP technical support was totally useless - until HP FINALLY decided to up date its drivers to account for my/many people's downloading of Internet Explorer 7. As this is now done, and you cannot easily uninstall IE7 and go back to IE6: try again (1) HP Director and if not (2) I think update drivers or (3) uninstall / reinstall. Hope it helps.
Apr 04, 2007 | HP PSC 2410 All-In-One InkJet Printer
Computers & Internet Logo
14 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
