Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Finally hooked up water to refrigerator but water continues to flow from icemaker and through door, How do you stop it?
  • 82 Answers
SOURCE: icemaker stopped
Ok that means you need a new water valve. That is the part that the water supply from the wall connects to.
Posted on Dec 06, 2008
  • 105 Answers
SOURCE: water seems to be flowing into icemaker fine.
If your freezer temperaures are good i.e. it freezes ice cream and the like, then you need to replace trhe icemaker. Typically, under normal conditions, the icemaker would dump a load of cubes @ every 1-1/2 hours. Icemaker part number WR30x10093 @ $148.00 from Marcone Appinace parts or AP Wagner
Posted on Apr 09, 2009
bobicehouse
  • 1524 Answers
SOURCE: I have a side by side refrigerator/freezer with
Check the defrost, if the coils have frost no cold air will circulate. Freezer must be 12 degrees F. for ice maker to work.
Posted on May 01, 2009
  • 30 Answers
SOURCE: Water not flowing through Refrigerator
Check the valve again. It is most likely a needle type valve that pierces the copper pipe.
Turn off the water to that pipe or the whole house. Remove the valve. Check the valve for build up or damage. If necessary replace the valve in the same exact place, other wise you will have two holes and one valve.
This could be caused by two things, hard water or electrolysis. Mineral deposits will form on practically anything. Electrolysis occurs between two different metals, ie copper and probably stainless steel.
Posted on May 15, 2009
TheMobilian
  • 8220 Answers
SOURCE: water continually drips from the freezer door
The lever you push for water does nothing mechanically to open any water valve. All it does is activate a solenoid coil on the water valve. The water valve itself is dripping like a faucet and needs to be replaced. To replace the valve shut off the water supply and disconnect the water line from the valve. Install the new one. Nothing to it.
Posted on Apr 29, 2010
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Having a problem with Kenmore refrigerator, model number 106.78862891, icemaker. The water going into the icemaker will not stop. It has a continuous stream of water. The icemaker makes ice when I MANUALLY...
first checkthe inlet solinoid valve if has a continuity or when u energized valve it activate or produce magnet that open the valve and water enter may this solinoid is stuck up try to dismantle. or check or clean the water level sensor using sand paper or rating 1000
Feb 01, 2011 | Kenmore Refrigerators
When the water line is hooked up to the back of fridge and the line is turned on the refrigerator leaks water out the ice dispensor and does not shut off the flow of water to the fridge.Thus causing it to...
the water soliniod maybe clogged with calcium. if you get it loose you can take the plastic hose loos from the icemaker side of the water valve see if it is dripping or running out of there. if alot is coming out maybe getting voltage too long from the icemaker. it will be one or the other.
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My icemaker stop working but the water dispenser still working I check both water lines from the filter its ok but can't check the freezer line by icemaker. turly don't know why the water will not flow...
If there is no ice in the ice mold of the ice maker, you can pour enough water in to make cubes, wait an hour or so for the icemaker to cycle.( freeze and dump the ice). If it does, then your water valve on the back of the refrigerator that the main water line hooks up to is bad. Replace it. The valve has two sides to it. An ice maker side and a water resevoir side. One side can be bad allowing the other to work.
If the ice maker does not cycle and dump the cubes then you probably have an ice maker problem.
Jun 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water flowing into the icemaker. The water is going into the cold water on the door. However, when I take the line off for the icemaker... no water comes out. I see that there are 3 connection for the...
The line to the icemaker won't have water coming out until the icemaker cycles and energizes the solenoid valve. check the inlet tube where it goes into the icemaker. sometimes this freezes shut. you can also check the continuity of the icemaker solenoid.
May 05, 2010 | Frigidaire FRS23R4A Side by Side...
Our Jenn air fridge is a few yrs old. A few
ok stop the water // the water valve is bad..very bad . change it ..its a dual valve in the back . right where the lin is hooked up . this will correct problem .. **** hope this helps . i think it will .. / feed back pls ..
Jan 12, 2010 | Refrigerators
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water flowing to the icemaker would not stop. It over flowed the
sounds like the water switch is stuckopen or the valve is. Is the water going to the icemaker or thru the door. If the icemaker is overflowing and doesnt shut off then unplug unit,still coming in change the valve. Not coming in then look at the switch.
Jun 10, 2009 | Kenmore 53542 / 53544 Side by Side...
Icemaker won't fill with water
If you would like a repair manual for your refrigerator, you can get one here. These are helpful to have in case you have other issues with the fridge.
Thanks
Sep 29, 2008 | Samsung RS2630WW Side by Side Refrigerator
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
20 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
