Question about Southwestern Bell GH3150 Cordless Phone
Southwesten bell FF888
Could anyone tell me why I'm not getting any dialling tone when I pick up even though I can still receive calls? Many thanks
0 characters
1 Points
I have a BT6500. It has been working fine until this week. I can reeive incoming call but can not dial out even though there is a dialling tone.
It sounds as though the tone dialler has stopped working. I think you'll have to replace the motherboard or telephone.
Feb 12, 2015 | Phones
Phone does not dial out any numbers.
Check the side of the phone. Look for TONE / PULSE selection.
MOVE it back and forth and leave it to TONE.
Test it again,
Jan 18, 2014 | Northwest Bell Nw Bell Wht Corded - Big...
I have a retro Conair SW2504 phone. I can't dial out
Is there a switch to select pulse or tone dialling? If so try it in both positions.
Jan 10, 2013 | Conair SW-2504GPH Corded Phone
Not receiving or dialling
1) if there no diallling tone test a) battery with VOM, clean the contacts batteries with ethylic alcohol with cotton swab. b) test the antenna is o.k or replace
2) the voltage line will be 48 Vdc , you must test it. use another phone that you know is working fine.
3) if the another phone work the line is the problem call to the company
4) if work replace the batte or antenaa or the phone completely.
God bless you
Sep 17, 2012 | Phones
Phone can receive calls but not make them.
hello i have a solution, you need to change you dialing mode on the base option, the deafult is "tone dialling", change to "pulse tone " this fix my problem on my A495 gigaset.
May 16, 2012 | Phones
Speed dial
1. lift the handset and listen for the dial tone. 2. press the store button 3. dial the number that you wish to store 4. press the store button a second time 5. press one of the numbers on the phone [0-9] and that will become the speed dial number. 6. make a record of the speed dial number and the name of the person it will call.
Then when you want the person on speed dial number 5, just pick up the receiver, get a dial tone and push 5. Thats it!
ps - kindly rate my answer as helpful. thanks
Feb 19, 2010 | Southwestern Bell Freedom Phone FM2552
My BT Verve 450 digital phone set won't ring out /incoming call
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
Dec 08, 2008 | Uniden Cordless Phone
Cordless telephone sw/from pulse to tone
check this link and hope it will solve the problem
Aug 15, 2008 | Uniden Cordless Phone
No dialling tone - just a beeping sound
It sounds like the handset is not 'registered' to the base station/cradle. Solution may be in the user handbook, which you should be able to download at :
Jun 23, 2008 | NTL VS1500 Cordless Phone
Southwestern Bell GH3150 Cordless Phone Logo
35 people viewed this question
Top Southwestern Bell Phones Experts
Andrew Taylor
Andrew Taylor
Outback Jack
Outback Jack
Are you a Southwestern Bell Phone Expert? Answer questions, earn points and help others
