Question about HP MS-7548 System Board Motherboard Aspen-GL8E ATX Socket 940 Mfr P/N FQ562-69002
Ms-7548 mobo no post beep and screen goes black after startup
Things tried; reseating ram,rtcrst, minimum system config, swapped out psu, removed cmos batt for 20 mins. nothing works i reseat my ram after discharging remaining power and the hp start up screen appears on screen, the bios load screen then windows system reastoration question for a sec or two then the screen blacks out again.
  • HP Master
  • 4,006 Answers
This sounds like you have picked up a virus there are a few that will do this, you will need to reformat the hard drive. or use a backup disc if you have one made to install on computer. make sure you only go into computer in safe mode and use virus software to try and remove it. this virus attacks the startup file on the hard drive, and the reg files allocation. hope this helps failing this the hard drive has wiped its self when it has not shut down properly.
Posted on May 09, 2014
  • 81 Answers
SOURCE: Corrupted screen display even at BIOS startup
The bios boots without loading the Graphics drivers. The problem is with the monitor itself.
Buy a new monitor. Keep an eye out on www.newegg.com they often sell monitors at 22" for 169.00
Posted on May 07, 2009
parrotheadpc
  • 2600 Answers
SOURCE: hp pavillion dv9000 blank screen on start up
Sounds like you are having a video issue on the motherboard and that is not a software or easy fix. Most people have to change out their motherboards when it comes down it in regards to this type of activity.
Posted on Aug 30, 2009
  • 50 Answers
SOURCE: HPG6000 Power Problems
Your motherboard is dead. u need to replace your motherboard. if it was any hardware device problem it will stay on but will not show any display but the leds will stay longer than 10 seconds. i suggest you find a hp authorised service center and let them diagnose. i'm pretty sure your motherboard is dead.sorry to say man.good luck
Posted on Sep 21, 2009
AldRezaine
  • 995 Answers
SOURCE: I have laptop HP g6000 and when i push the star
There is a problem with the power supply. Replace the power supply with a new one.
Posted on Oct 30, 2009
  • 1027 Answers
SOURCE: i have hp dv9700, after improper shutdown kept rebooting
What happened is that you interrupted the disk write on 'saving settings'. Very BAD. You may be able to start in safe mode, by pressing F8 while windows is starting, then selecting options to attempt to repair. The alternative, is to boot from the windows CD and select 'repair'.
Posted on Feb 10, 2010
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Sc 5100 beeps on startup
These are EACH... DIFFERENT SYSTEM CONFIGURATION ERRORS at boot
Check that you have not changed any hardware/added any hardware and that these changes were/or have not TAKEN EFFECT yet
Power down system.... use CMOS RESET pin config jumper to reset your boot configuration(s) changes
Multi-"BEEP" error messages are usually connected to RAM CONFIGS. and I would suggest uninstalling ram chips..... but ONLY AFTER FULL SYSTEM "power drainage"!!!... i.e. pulling power plug from your PSU, removing system battery or unplugging it's terminal wiring mobo connector, and pressing the POWER BUTTON on your system
Jun 04, 2013 | Computers & Internet
I have a Soya SY-7VCA mobo that hasn't been used for about 6 years. Upon bootup, I received a CMOS checksum error message, but was still able to load a copy of Windows 98SE that I had on floppy. After...
Probably your BIOS battery, replace that and setup you BIOS again and it should be fine. BIOS batteries look like little round watch batteries.
Any more questions just let me know.
Thanks
John
Feb 14, 2011 | Soyo SY-7VCA Motherboard
Mobo fried? Beeps when startup but no video. I reseated ram and video card, with no luck. Both fans work and it sounds like it is booting. I tried older video card too but nothing. Thanks for any...
Try removing the display card and using the onboard VGA. Remove the BIOS/CMOS battery for about a minute and then reinstall it in the correct orientation. This will reset the BIOS/CMOS to it's default settings. You say it beeps once, this means that it is fine the mainboard is ok, it is not experiencing any problems. If it beeps in a continuous manner then it is the RAM that is causing the problems, I would say that the default settings may solve your troubles. Remember to enter the BIOS/CMOS when during boot up to reset the date and time by hitting the delete key. Also try entering the BIOS/CMOS even if you can't see any thing on screen, by doing this it may come up. let me know how it goes, I am here to help.
Thanking you
damnor01
Nov 09, 2010 | HP Compaq Presario SR5450F Desktop PC
When I turn on the computer it starts to beep every four or five seconds; it doesn't even turn on the screen. The display at the motherboard is "04". What does it mean? There was nothing wrong with my...
This is do with a device failure it can be the RAM of your system , Try swapping the RAM and if you find two RAM in your system remove one to check the error.
Kindly send me your valuable feedback.
Jan 16, 2010 | Abit KV8 Pro Motherboard
Computer starts but does not post Athlon XP KM4M DDR
if the system made no beeps after the machine was booted with no ram its a bad board...sorry
Aug 10, 2009 | Computers & Internet
Gateway GT5228 Will NOT Startup
TAKE OUT YOUR MEMORY CHIPS,AND INSERT 1 AT A TIME AND TRY.
IT COULD BE YOUR RAM THAT IS FAULTY THATS WHY ITS DOING THIS
Jul 04, 2009 | Gateway GT5228 (7156) PC Desktop
Fans runs but no post,no beeps.
The best advice I can give you is to remove the motherboard battery (UNPLUG THE PSU BEFORE YOU WORK ON THE MOTHERBOARD) and let the system sit for about an hour. If the CMOS settings are corrupted, removing the battery will erase the corrupted data in the CMOS, which will automatically reset the CMOS to the default settings... Then, plug the battery back into the motherboard, and try to boot the system...
If that doesn't work, you should disconnect EVERYTHING attached to the PSU, and remove ALL of the add-in cards (modem, NIC, soundcard, TV tuner, whatever you have), and install ONLY the CPU, the heatsink/fan (don't forget to PLUG THE CPU FAN IN), ONE stick of RAM... you get the idea. DISCONNECT the HDD, the FDD, the optical drive, and ANYTHING ELSE from the PSU. When you're ready to test the system, you should have ONLY the CPU, the HSF, and one DIMM plugged into the motherboard. Attach the PSU connectors (both the main ATX connector AND the auxiliary 4-pin 12-volt connector) to the motherboard, and try to boot the system. If it works, SHUT DOWN and UNPLUG THE PSU; then install ONE component (the floppy drive, for example), reattach the PSU, and reboot the system. If the system POSTs, shut down, unplug, and add another device. If the system does NOT complete the POST process, the last piece of hardware you installed is probably the culprit.
Take your time with this; be methodical, and make GOOD notes about the steps you've followed, so we can help you work through this problem...
Best of luck to you; keep us "posted" on your progress...
Jan 27, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Dead Mobo?
Do you have both power connectors from the PSU hooked up?
You need both the large one near the ram, and the smaller square 4-pin one near the printer port
Nov 22, 2007 | FIC K8-800T Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
HP MS-7548 System Board Motherboard Aspen-GL8E ATX Socket 940 Mfr P/N FQ562-69002 Logo
190 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
