Question about LG Computers & Internet
Mr right TO INSTALL OS IN MY LAPTOP BUT FUNCTIONAL KEYS F2 AND F12 NOT WORKING I MEAN IT'S STUCK
    Top Expert:
  • LG Master
  • 26,670 Answers
Download the system drivers from your manufacturers web site.
Posted on May 09, 2014
  • 73 Answers
SOURCE: Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0 may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
Posted on Feb 08, 2009
  • 66 Answers
SOURCE: bios stuck
did you try removing each stick of ram individually or the hdd then rebooting?
Posted on Nov 03, 2009
  • 540 Answers
SOURCE: When I turn the laptop on (L350) the screen starts
The laptop can not detect the hard drive please remove the hard drive and then reseat it if the problem persist then replace the hard drive.
Posted on Feb 09, 2010
  • 85 Answers
SOURCE: Function keys F1 thru F12 don't work
Keyboard might have gone bad. Try hooking up a external keyboard and see if they work. If they don't then you have a motherboard issue. If they do then it is a keyboard issue. If you lucky it is just a keyboard then you can get one here for 20 bucks.
http://www.amazon.com/dp/B000MMCJQY/?tag=ricksphotograpag1-20
It is really easy to replace.
Posted on Apr 14, 2010
  • 1082 Answers
SOURCE: I have a eee PC
Check the CONTROL PANEL, SOUND and make sure it is set to windows default. Also make sure sound is not diabled.
Posted on Aug 08, 2010
When I try to boot my computer, it says setup entry key detected when I press f2 and network boot key detected if I press f12. I don't remember putting any such passwords. OS is Windows XP.how to fix?
The function keys you mentioned are part of the BIOS itself. They are written into the BIOS firmware. If you are saying that there is a password associated WITH those keys, then that was added later by some user. It would be stored in the BIOS though, not part of the OS.
Feb 20, 2016 | Computers & Internet
How do i change the funtions of the F1 to F12 keys. They are currently set up so that when i select F2 the brightness is adjusted.
I'm not sure I understand? What or Why do you want to change it? usually , when the computer is booted you use the function keys. If you reboot the laptop and immediately tap F keys you will get , say, BIOS setup, Boot Menu, Recovery program, etc. You didn't post the Make, Model of Laptop or the OS you are using?
Apr 19, 2013 | Computers & Internet
Linux mint 12 won't boot from CD
Restart your computer, press repetedly a key to enter BIOS, normally Del, go to Advanced BIOS Features probably and change to boot primarly from CD/DVD (1st Boot Device CD/DVD , or something like that), save and exit BIOS, and restart your computer with Linux Mint CD inside. Be aware that if you make wrong changes in BIOS, you could damage your computer.
Feb 18, 2012 | Acer TravelMate 4001LCi Notebook
My lenovo S10-2 wont turn on correctly it comes up with press f2 or f12 i?
What happens after you press f2 or f12? Usually if it gets stuck on lenovo logo it means that there is something wrong with BIOS so you need to reset it. But if happens that it gives you error message after that window it could be a OS error or it could be the HDD is bad.
Apr 21, 2011 | Lenovo IdeaPad S10-1208Uw Netbook
I have a lot of virus in my computer, it is not allowing me to go online in normal mode or SMWN. i tried all possibilities of taking the virus out of computer but in vain. Finally decided to clean install...
It differs by every model but the most common keys other than F12 or F10 are F2 and Esc. Try seeing if those two keys take you to the boot menu.
Apr 15, 2011 | Computers & Internet
I have HP G42-247 laptop.when i press f2 key without function key it work as contrast brightness and when i pree with function kry it work good as f2 key work. I mean function key is working...
HOW-TO: Disable The Fn + Function on HP Laptops - HP Communities
h20435.www2.hp.com/t5/The-Next-Bench...Fn-Function-on-HP-Laptops/.../77527May 1, 2012 - On most HP and Compaq notebook PCs, it is necessary to press and hold the function key (fn) while pressing one of the f1 through f12 keys to activate ... Use the up-arrow or down-arrow keys to navigate to the Action Keys Mode option, and then press the "enter" key to display the Enable / Disable menu.
Feb 17, 2018 | Computers & Internet
My acer aspire 5315 always show boot prepare os. When i want to install windows it cannot show cd boot (booting from cd/dvd) so i can't install windows. what is the solution sir? thank.
Restart you computer then hit F2 for Boot Bios Setting then GO TO Advance. Change the SATA Mode . ACHE. ot IDE. or Comfatibility.. then enable the F12 boot. make in enable. the hit F10 for save and exit...
Insert you cd os Installer then hit F12 for **** menu. select the CDROOM for boot....
Dec 30, 2009 | Acer Aspire 5315 Notebook
Where is function key ?
Sir,
Definetly u want keyboard to press F8 for installating OS. Get another keyboard and connect it.
Thanks Good Luck
Sep 12, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
F2 & F12 keys don't work during bootup w/ Trust KB-2200 Keyboard
It is because of the "Function Key" It needs to be enabled for thenm to work. :))
Apr 11, 2009 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
