Question about Kenmore 24 in. 15689 Built-in Dishwasher
Clean light flashes and dishwasher wont start
Clean light flashes but dishwasher wont start
  • Anonymous Mar 31, 2014
    dishwasher wont work just flashes error code clean s
  • 6,784 Answers
HI, this is a dirty filter alert. it could also be a control fault as well. clean the filter and, disposal as well. if this alert cannot be cleared, replace the control board or, timer.
Posted on Jun 22, 2009
SOURCE: kenmore dishwasher wont start blinking clean light
Try pressing normalwash-heatdry-normalwash-heatdry-normalwash-heatdry-normalwash-heat then all the lights come on. Let run for a little bit. then keep pressing the start button. untell the unit shuts off, then try running a cycle. The control board has a memory in it. So if you have cold water running in it one time. It will take longer to warm up. Your memory in the control board says its taking to long to warm up. Shutting down thinking their is something wrong with your heating cycle.
Posted on Apr 30, 2008
jsrock516
  • 5911 Answers
SOURCE: Green "Clean" light keeps flashing, dishwasher won't start
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Sep 15, 2009
SOURCE: The clean light in my Kenmore dishwasher keeps
It has to do with the water temperture, either the water entering the dishwasher is too cold and the heater can't get it up to temp, or the heater unit has problems... Push the Air dry ,then the sani wash buttons a few times and all the lights will light, it resets the computer .
Posted on Nov 10, 2009
  • 1382 Answers
SOURCE: Kitchenaid KUDS01FL -Dishwasher -
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Posted on May 20, 2010
Testimonial: "SOLVED THE PROBLEM"
  • 949 Answers
SOURCE: The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
Posted on May 23, 2010
Green clean light wont stop blinking unable to use dishwasher . It is an energy saver. the drain button works ..and when you push start the light comes on but will not run for cleaning
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 19, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Clean light flashes on my KitchenAid KUDS01DJ and it wont run
My dishwasher did the same thing. The repair guy fixed it and told us how to reset next time it happens: press: Hi temp then Energy saver then Hi Temp then Energy saver do this quickly over 5 seconds all the lights should come on Then,turn off the breaker for one minute then, go back to the dishwasher and press cancel. All the lights should turn off. Start dishwasher as usual. If the cause was just a brain fart, the dishwasher should work.
Jun 03, 2010 | KitchenAid KUDS01DJ - Multiple Color...
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Kenmore 665 17033400 Elite dishwasher clean light flashes 7 times and it wont run. i used the reset combination, all lights lit and stayed lit until i pressed reset. Then it started a wash. now the wash...
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Jan 14, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Flashing clean light and wont start. Is there a sequence of buttons to reset the switchboard?
sani rinse---heated dry---sani rinse---- heated dry.. all the lights on console should light then close the door, let run for 20 -30 secs, and cancel the cycle, if the problem happens again yo need t call a servicer. 1 time maybe a fluke but to happen again indicates a heating, issue somewhere(or a lack of heating)
Mar 04, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Kenmore 24 in. 15689 Built-in Dishwasher Logo
439 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
