Question about Pioneer DEH-P690UB CD Player
How to conect super 3 d - Pioneer DEH-P690UB CD Player
Supersilent 30 gives a small sound then a click thats it
I had the same issue with my ss 20-a. I believe that it was because I used the wrong oil. Silent aire claims that you have to use their special synthetic oil. I did not know this and after nine months my compressor stopped working. I opened up the compressor and did a little tinkering. I found that the compressor shaft was stuck and not spinning. Taking a wrench and a cloth I was able to loosen it. Now it spins freely and produces pressure. I just have to wait for the silent air oil before I will let it pressurize fully.
Jan 17, 2013 | Silentaire Technology Super Silent 30-Tc...
Broken usb conection in verbatium hd
if you are mechanically inclined and have a soldering outfit you can probably just re solder the connections, and or find a replacement USB connector if it is broken and replace it
Apr 05, 2012 | Verbatim 97397 Store N Go Super Speed Usb...
How to conect super nintendo to HD tv ?
put the composite/ yellow into the yellow white into the white and red into the red you can find one of these with any gc or n64, or use the coaxial that was for nes ,
those are your only options back then ,
but expect green lines , as mine does that on any hd tv
Jan 17, 2012 | Nintendo Super NES Console
My 2002 super dyna glide's speedometer quit, any advice?
speed-o is electric check for loose conections. wiggle conecters. if not there try checking contanuity. mine had a broken wire between conector on the neck and speed-o, where the tach was spliced in. under the outer sheath so it's hard to find visualy, but the meater will show a break. make sure to wiggle harnass while teasting.
Jul 12, 2011 | 2002 Harley Davidson FXD Dyna Super Glide
Need to find witch wire on coil conect yellow wire tohow to wire HD mini tach on 09 dana
2004 Harley Davidson FXD-FXDI Dyna Super Glide Motorcycle Specs and
Specifications
Mar 04, 2011 | 2004 Harley Davidson FXD - FXDI Dyna Super...
When I turn on the Snes just appears a black screen, i check the RF conection and it´s ok, right channel 3 i clean where you insert the games with alchol it doesn´t work
Well you could try cleanining the gamepacks with qutips and rubbing alcohal.
But the bad scenario is that the super nintendo console is on its way out.
Dec 23, 2010 | Nintendo Super NES Console
Have buzzing in super nintendo, replaced rf switch and still have it, any ideas?
hey i would try another rf switch cause they really mass pruduce those things so the wiring and sodering is slopy and if that dont work it migh be the nintendo it's self also try to use a rca cable the one with the red yellow white conecters they give you much better sound qaulity.
Nov 10, 2009 | Nintendo Super NES Console
Pioneer DEH-P690UB CD Player Logo
20 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
