Question about Kenmore 43142 Front Load Washer
How to change door direction on a zanussi zwf16381w?
I cant get child lock off zanussi 6kg 1200 and cant find the manual please help
Zanussi has several washer models with 6 KG capacity 1200 RPM spin speed specifications. You need the model number to find the manual here: http://www.zanussi.co.uk/support/manuals/ . The model number for a front load washer is inside the door on the lower right of the opening.
For the ZWG7120P, you need to press and hold both the Temperature and the Spin buttons for 6 seconds to toggle the lock on or off. (This time is approximate.) These are the two buttons closest to the program selector dial. There is a small padlock icon in a curved line below and between the buttons. The direct link to the manual for this model in English is http://www.electrolux-ui.com//DocumentDownLoad.aspx?DocURL=2010\132\948930EN.pdf .
I hope this helps. Please add a comment with your washer model if the above child lock directions do not work on your machine.
Oct 06, 2016 | Zanussi Washing Machines
E40 fault on zanussi washing machine is it worth repairing or to buy a new one 8-9 yrs old ?
A Zanussi E40 error usually indicates "Door open.Check interlock and associated wiring check door latch,check module and connections." However, what most people don't know is that most manufacturers route the poser to the door interlock through the same curcuit that powers up the carbon brushes on the motor. So if your motor brushes are worn down, the door won't lock. Your machine is about the right age for its brushes to be worn out, so I would check this out first. Motor brushes are cheap, easily available on Ebay and fairly easy to fit. Take the current brushes out, if they are less that three quarters of a centimeter long, changing them is a highly likely fix for your problem
Oct 31, 2015 | Zanussi Washing Machines
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Official Zanussi Site Parts Accessories for Appliances
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
Zanussi model zwf16381w I've pulled the black pipe off from the bottom by the over flow drainage and it's now leaking every were .
WHY did you do that? That's the drain hose. All the water from every wash cycle needs to go out that hose so the machine can get rid of it. Please reconnect that hose.
Jul 31, 2014 | Washing Machines
Broken door release. The wire connecting both latches to the release button has broken. Can I get a replacement?
Yes by contacting a local domestic appliance spares shop or wholesaler in your area or by contacting Zanussi Support directly statingthe model no and serial number of your machine.
Oct 07, 2009 | Zanussi Dryers
How to change door seal on zanussi fl 1080 . how do i remove old torn one and fit new
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install
Thank You for contacting Fixya.com
Aug 03, 2009 | Zanussi ZWF1440 Front Load Washer
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
May 19, 2009 | Zanussi Washing Machines
Zanussi fl815
sent you an email direct - hope it helps
Jun 29, 2008 | Zanussi FLA1001W Front Load Washer
Kenmore 43142 Front Load Washer Logo
16 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
