Question about Reptile
Why are anole lizards colorful - Reptile
Spectracide was sprayed in my garage on Monday. Today I found a lizard in my garage & it is sick. Is there anything I can do for it?
the SDS Sheet doesn't mention treatment for lizards. It is a weed treatment not an insecticide, so may not harm the lizard long term. Try giving it water and cat food.
Labels and SDS Spectracide
Jul 28, 2017 | Cars & Trucks
We have white lizards that are a little bigger then the typical little brown lizards. What are they, desert iguanas???
depends on where you live but they could be geckoes
they are up to 4" long , vary in color from almost clear white to brown and grey
have fat toes that have small suction cups at the tips something like a frog foot
run on walls and ceilings in houses or on trees and other foliage
eat flies, moths, spiders and any other small live objects
go google and type in --- what lizard is that -- and there will be pages identifying each lizard by photo
May 04, 2016 | Heating & Cooling
How can I remove hundreds of little Garden Lizards with a yellow stripe down the side from my garden?
you leave them alone they eat all the BAD bugs you might find out there .
Sep 20, 2015 | Garden
Do lizards lay eggs? Or how do they reproduce?
Yes lizards lay eggs, like birds, they are raptors.
Jun 03, 2015 | Cars & Trucks
IS "IS" REFERRED TO AS PLEURAL OR SINGULAR?
IS can be used if you refer to one type of lizard....
Is there a poisonous species of lizard in Alabama?....SINGULAR
Are there poisonous lizards in Alabama?....PLEURAL
Lizards ARE the subject.
Regards,
Dennis
Sep 08, 2014 | Carson-Dellosa BIG OF SENTENCE BUILDING +
What can I put around the property to get rid of the lizards
take this to a reptile site or rodent control company or ask an SPCA worker.
Sep 06, 2014 | Cars & Trucks
What kind of lighting is required for a lizard?
This depends on the type of lizard - most lizards that are not nocturnal require full spectrum lighting for 10-12 hours each day in order to absorb the proper amount of calcium and vitamin D.
Sep 04, 2012 | Aqueon Reptile
My lizard lights are all of a sudden not working? The fuse looks fine. These lights are only a a year old.
The controller failed. The assumption here too is that you are nowhere close to 16 of the 7 color modules on one controller.
While LEDs can fail early, they usually fail far earlier than what you have experienced and they would not all fail at once. Unless you were zapped by lightning. It is just the nature of the devices. The LEDs can be tested when unplugged, a 3 volt battery is always safe for testing. They will only light when the battery is correct polarity for the LED, so you do need to try both ways.
It should not have failed so early. You might give them a call and see if it is a chronic problem Their customer service number is 1-866-277-9598
Feb 03, 2012 | Kuryakyn Kuryakyn Lizard Lights Double...
Open Questions:
Reptile Logo
97 people viewed this question
Top Reptile Experts
windryder
Level 1 Expert
john h
Ned Halaweh
Ned Halaweh
Are you a Reptile Expert? Answer questions, earn points and help others
