Question about Apple MacBook Pro Notebook
I have a macbook air and a little colored spinning circle on my screen and it will not let me close a file that is open or even shut down the computer, can you help me?
    Master:
  • Apple Master
  • 545 Answers
Ctrl+click on the icon will allow you to force quit.
Posted on Jul 17, 2014
  • 65 Answers
SOURCE: Hello, I'v got a MacBook
Try:
1. Turn your MacBook Air off by holding down the power button for about 10 seconds.
2. Hold down one of the Shift keys and press the power button for a few seconds. Keep holding the shift key for about 1/2 minute. This will start the machine in "Safe Mode." It will check to make sure there are no errors on your hard drive and do other tasks to hopefully fix your problem.
3. Once you see your Desktop (if you do), click the Apple menu and click "Shutdown".
4. Start the computer normally by holding down the power button for a couple seconds.
If this doesn't work, you may need to reinstall the operating system. On a MacBook Air, that's a bit more complicated. You'll need either the external DVD drive (an optional purchase for the Air) or another computer. Your computer manual explains how to install software on that other computer (may or may not be necessary) so that you can use that computer's DVD drive to put the disc in and reinstall Mac OS X operating system.
Good luck! Please let us know if you have further questions or problems.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Posted on May 02, 2010
shadowqat
  • 72 Answers
SOURCE: my apple macbook air will
Your best bet is to reset the System Management Controller;
http://support.apple.com/kb/ht3964
...and then reset the Parameter RAM:
http://support.apple.com/kb/ht1379
If it persists after that, try Safe Mode:
http://support.apple.com/kb/ht1455
...if that persists, try booting to your install DVD and running Disk Utility:
http://support.apple.com/kb/ts1417
..also note in this article that if for some reason you are unable to boot into your Install DVD the instructions for using fsck will do the same thing.
If that fails to resolve the issue, you'll want to reinstall the system, but that is a bit more of a sticky wicket since you're on a Macbook Air that does not have an optical drive. You can use remote disc sharing with another Mac to do this:
http://support.apple.com/kb/ht1131
...and then boot to that shared disc:
http://support.apple.com/kb/HT2129
..and then reinstall:
http://support.apple.com/kb/ht1710.
If none of these steps resolve the issue, it will likely need repair at an Apple Authorized Service Provider or Apple Store.
Posted on Aug 30, 2010
MacAppleTech
  • 206 Answers
SOURCE: MacBook Air. On start up, system tells me that
Thank you for contacting Fixya Support.
Try these steps:
- - Reboot your Mac
- - Upon restarting your Mac, press the Shift key.
- - Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
- - When you see the Spinning gear, release the Shift key.
- - Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
- - You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
- - Once within the Desktop in Safe Mode
- - From the Finder Menu, click Go> Go to Folder
- - Type in this line: /System/Library/StartupItems
- - This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
- - Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
This should help.
Regards,
-Mactechtrainer
Posted on Sep 04, 2010
  • 15 Answers
It may be a possibility that the hard drive has gone bad or a connection to the hard drive. The spinning wheel and apple signify the kernel boot, or in other words, the process in which the machine finds the hd and os/software.. you need to bring your machine into an authorized repair center to have a system diagnosis to verify that no other parts of the machine are bad. That model is notorious for having bad hd's.
Posted on Mar 02, 2011
  • 9 Answers
SOURCE: when i turn on my
did you install anything new or damage your comp?
Posted on Jul 16, 2011
Having problem to shut macbook
Click the Apple logo at the top left hand corner of your screen and select "Force Quit". On the small window that pops up, select the trouble app and click Force Quit. If the app does not close, hold down the power button until the screen goes black. This will not harm your computer (since it's a Mac) and you can boot it back up afterwards.
Nov 06, 2014 | Apple MacBook Air 11.6" (TD73785W) Mac...
How to remove a little circle of color in spinning
Ctrl+Click on the icon in the dock and select force quit. Make sure you don't have too many other processes running at the same time.
May 14, 2014 | Apple MacBook Pro Notebook
I have a little spinning colored circle on my screen and it will not let me close a file that i had open or shut down the computer, can you help me?
Press these three keys: command+option+esc.
You'll see a list of the apps you currently have open. At least one of them will probably say "(Not Responding)" next to the app name.
For any apps which are listed as "Not Responding", simply click the app name and then click "Force Quit".
May 08, 2014 | Computers & Internet
Mac Pro laptop is freezing up...the little circle of colors in spinning, spinning and nothing is happening...tho the icon says I'm active on the internet, I can't get there. nor can I open any programs on...
Start with the left shift held down, this does some system housework and gives "safe boot" see if that helps, then look in fixya tips for how to repair the hard drive and permissions.
Oct 29, 2010 | Apple MacBook Pro Notebook
I have an Macbook Pro, and I get a spinning pinwheel of color that stops everything from time to time or I get my safari totally shutting down. What up?
That little pinwheel is the Mac "loading" wheel. Kind of like the hourglass in windows. I found a link on how to reduce the loading wheel in Safari at this website. http://reviews.cnet.com/8301-13727_7-10328447-263.html
Happy computing.
-CompDoctor
Feb 22, 2010 | Apple MacBook Pro Laptop Computer with...
MacBook Desktop Lost My Desktop Folders
Hello, it semms that you have a "permission" issue, or that you are accesing another account on the computer without noticing it. Please repair disk and permissions from the disk utility on your install DVD:
- Insert install DVD
- reboot the mac holding the C key
- choose english
- Go to the utilities menu and choose Disk Utility
- In the disk utility window, SOS tab, select your drive, and hit repair disk and repair permissions
- reboot
Also check that you are accessing the account that you want and not another one: log out, and log in...
May 31, 2009 | Apple Power Mac G4 Dual Mac Desktop
If the colour circle shows... find a tiny bit of wallpaper showing through the back, then click. Then, you should see it labled finder instead of preview. Next, click on the blue apple. If it doesn't happen immediatly, a dropdown bar will show in a couple minutes. In the dropout bar, click Force Quit. It usually takes 2 minutes for the Force Quit window to show up. It'll ask you what you want to force quit,  Look at the choices and force quit all of the ones that say: NOT RESPONDING. Then the computer will clear up for a while, in wich you can probably preview your pictures.
Aug 12, 2008 | Apple Power Mac G4 Dual Mac Desktop
"Open" written on screen
There is supposed to be a little plastic piece that pushes down a button that tels it that it that the door is closed that plastic piece is broken off. Look for it and glue a little piece of plastic on it, should fix it.
Jun 04, 2008 | Toshiba SD-P1600 Portable DVD Player
Apple MacBook Pro Notebook Logo
77 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
