Question about Dell 2130cn Laser Printer
Light sensitive drum - Dell 2130cn Laser Printer
What is a photo conductor
The photo conductor is the round drum unit that is light sensitive. The laser in the printer writes an image of what you want to print on the drum and then the toner is applied to the drum and transferred to the paper.
Aug 30, 2015 | Ricoh Aficio 1515MF All-In-One Laser...
How to clean the drum on a konica minolta biz hub
YOU DONT Clean Drums!!! They are very sensitive to light. NO cleaning fluids!!!!! What model are we talking about There are internal devices that clean the drum 1. Cleaning Blade 2.The Erase Lamp and or 3. Cleaning roller. They may need to be replaced that is why the drum is dirty
Apr 08, 2014 | Minolta Office Equipment & Supplies
Brother HL-1250 owner's manual
Three Horizontal lines indicates a 'Light Burnt Drum'. The drum units are light sensitive. If they are left in the light too long they will be affected and it will show as black horizontal bars. The number of bars really depends on the circumference of the drum some are 2 some are 3 some can be 5 etc.
Solving this you can only replace the drum unit. Check with your local remanufacturing outlet to source a replacement drum unit at a price WAY better than buying new.
Apr 02, 2014 | Brother HL 1440 Laser Printer
Why does the drum need changing
The drum is where the images are created, a good drum means good printing quality, is sensitive to light, do not expose to sunlight directly and also expose to the light as less as you can. Other Brands of printers has the drum in the cartridges, every time that you replace the cartridge actually you are replacing the drum, but usually the drum last longer than the toner, Brother allows user to change drum when its need it, for example this drum last about 17,000 pages if you are not concern about quality you can reset the drum and keep using until the quality is not enough for you.
Aug 31, 2013 | Brother HL-4070CDW Printer
Paper prints with lines in the middle
if ur toner is empty (you can feel how light or heavy it is) replace toner if not replace ur drum. ( drum is photo sensitive dont leave out for more than 15 minutes and u will proboly see lines on the drum if it is defective.
Oct 11, 2011 | Dell 1720dn Laser Printer
Heavy black smudges over printing
hi,
  • Clean the printers drum.
  • The drum is a light-sensitive rotating cylinder where latent images are created.It comes together with the printers toner package.
  • If this doesn't solve it,have the drum replaced.
Hope this helps.Thanks!
Oct 02, 2011 | Brother HL-2040 Laser Printer
When hitting one drum, other drums are triggered... how do I fix that??
Usually there is a sensitivity parameter. Reduce the trigger sensitivity in the module. Refger to your user manual under "sensitivity".
Jun 01, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
ERROR MESSAGE 810?
E810 and/or "CHECK TONER/DRUM CRG" message on control panel.
Something is not right in the drum unit. Make sure that the drum unit and developer units are attatched together at the front and rear.
Use caution when removing, the drum is light and scratch sensitive.
If all is well there, either call a service tech or replace the drum unit
Jun 07, 2010 | Canon imageRUNNER 1310 Printer
What is drum error
The drum is the light sensitive device that "senses' the laser to create an image. They are replaceable, although usually expensive.
Good luck
Dec 12, 2008 | Brother DCP-7020 All-In-One Laser Printer
Print error
Replacing the drum should fix this issue. The PC drum, aka, photoconductive drum, is light sensitive, if it has been exposed long enough to light, it can cause this problem.
Jun 19, 2008 | Dell 1720dn Laser Printer
Dell 2130cn Laser Printer Logo
23 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
