Question about Encore Garden
How to install belt on pump drive of an encore mower
The belt goes around main pulley then 2 drive pulleys the tension arm keeps it snug, how do you install?
lester482529
  • 226 Answers
SOURCE: drive belt tensioner pulley bearing failed
go to parts tree .com. put your model# and make in then click deck assembly.they should have what you need .hope this helps
Posted on Jul 22, 2009
mowerman1857
  • 389 Answers
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Posted on Sep 30, 2009
mickey813
  • 472 Answers
SOURCE: Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Posted on Oct 15, 2009
mowerman1857
  • 389 Answers
SOURCE: how do i replace the belt on my troy bilt 42
You can loosen the bolts that hold the pulleys and guards far enough to slip the belt in, then tighten them back up. I have also carefully bent the guides back just far enough for the belt to go in, then bent them back in place
Posted on Oct 31, 2009
  • 5370 Answers
SOURCE: Need a belt diagram for
So as per your explanation, it indicates that , your mower has 6 pulleys.------ 1 motor driven pulley,3 blade pulleys and 2 accessory pulleys.That in total comes to 6.So for belt routing diagram for Murray 46" 6 pulley.Click this link below and see the belt routing diagram:---
http://technoanswers.blogspot.com/2011/09/belt-routing-diagram-for-murray-pro-16.html ----------- this will help.thanks.Helpmech.
Posted on Sep 05, 2011
How do i replace drive belt on husqvarna zero turn model#96645580
To replace EZT belt
Park the mower on a level surface. Engage the park brake.
EZT belt removal
NOTE: Be careful not to damage the fan blades on the EZT as this can affect cooling or damage the EZT.
  1. Remove the deck belt
  2. Create slack in the belt by pushing the spring loaded idler arm away from the belt.
  3. Rotate arm to release belt tension.
  4. The belt should now be able to be removed from the engine pulley and EZT pulleys.
Belt installation
  1. Wrap the EZT belt around the EZT pulleys.
  2. Wrap the belt around the engine pulley.
  3. Route the belt around the inside of the idler pulley while keeping tension off the belt and then slowly the idler assembly afterwards.
  4. Check that the belt is on all the pulleys correctly and test drive your unit.
  5. Afterward then re-install your mower deck once your are satisfied with the drive installation..
Feb 18, 2015 | Husqvarna Garden
Belt replace instructions
The accessory drive belt is a serpentine type belt that is driven by the crankshaft pulley
The belt drives the A/C compressor , alternator , power steering pump and water pump . Belt tension is maintained by an automatic belt tensioner .
Removal:
1. Using a wrench, rotate accessory drive belt tensioner counterclockwise until accessory drive belt can be removed from pulleys .
2. Remove accessory drive belt .
Installation:
NOTE: When installing drive belt on the pulleys, make sure that belt is properly routed and all V-grooves make proper contact with pulley grooves.
1. Install the accessory drive belt around all the pulleys except for the alternator pulley.
2. Using a wrench, rotate accessory drive belt tensioner counterclockwise until accessory drive belt can be installed on the alternator pulley .Release spring tension onto accessory drive belt .
Jul 23, 2014 | COMPASS 2008 AUTOMATIC REMOTE ONE WAY...
Looking for a belt tensioner for a 1997 Jeep Cherokee Country. Where would I look? Perhaps I am not calling it by its correct name as no one can even guess what I am looking for...Thanks!
Do you mean the tensioner pulley?
Then, I would look for something with a 1/2" square hole in a pivoting spring loaded pulley that is designed to put 'tension' on the serpentine belt.
Depending on the engine, it can be located in various positions.
REMOVAL & INSTALLATION - 8 cylinder engine Alternator Belt
  1. Loosen the alternator mounting and adjusting arm bolts.
  2. Pivot the alternator inward and remove the belt from the vehicle. To install:
  3. Install a new belt.
  4. Holding the alternator in place to maintain tension, tighten the alternator mounting and adjusting arm bolts.
Power Steering Belt
  1. Loosen the adjusting and mounting bolts on the front face of the steering pump cover plate (hub side).
  2. Pivot the power steering pump inward and remove the drive belt. To install:
  3. Install the drive belt.
  4. Holding the pump in place, tighten the adjusting arm bolt and the mounting bolts.
Air Conditioning Compressor Belt
  1. If the engine is equipped with an idler pulley, loosen the idler pulley adjusting bolt and remove the belt.
  2. If not equipped with an idler pulley, loosen the adjusting and mounting bolts.
  3. Pivot the air conditioning compressor inward and remove the drive belt.
  4. Installation is the reverse of removal.
Air Pump Drive Belt
  1. Loosen the adjusting arm bolt slightly. If necessary, also loosen the mounting bolt slightly and remove the drive belt. To install:
  2. Holding the pump in place, install the drive belt, then tighten the adjusting arm bolt and the mounting bolt.
Oct 17, 2010 | 1997 Jeep Grand Cherokee
Diagramm serpantine belt 2005 sprinter2500
Hi.
Here the belt routing for 2005 Dodge Sprinter 2005, whch was sold only with the 2.7 engine mounted:
Fig. Accessory Belt Routing-A/C Compressor (1), Power Steering Pump (2), Tensioner (3), Crankshaft Pulley (4), Water Pump (5), Alternator (6), Idler Pulley (7)-All Engines
Here a different view:
Here also the fan belt routing;
Fig. Fan belt routing-Fan pulley (1), Fan belt (2), Crankshaft pulley (3)-3.0L engine shown
PROCEDURE Removal & Installation
2.7L Engine
1. Loosen the tension adjust and remove the A/C compressor drive belt.
2. Attach a 3 / 8 inch drive ratchet to the automatic belt tensioner.
3. Rotate the belt tensioner counterclockwise to release the belt tension.
4. Remove the accessory drive belt, starting with the water pump pulley.
To install:
1. Position the accessory drive belt around every pulley except the water pump pulley.
2. Rotate the drive belt tensioner clockwise, install the accessory drive belt and release the tensioner.
3. Position the A/C Compressor drive belt over the crankshaft pulley and A/C compressor pulley.
4. Tighten the drive belt tensioner.
5. Ensure the belt is seated properly on all of the pulleys.
If this solution was helpful, then please do not forget to Accept.
Writing dedicate solution, sharing skills, researching and extracting info from service documents takes time, and your feedback is important for us.
If you repute any solution useful, please click on Accept.
All the best.
Ginko.
Sep 21, 2010 | Dodge Sprinter Cars & Trucks
I need to see a belt routing diagram for a Scotts Mower
This is for a Scotts 1642. Picture yourself sitting on the mower looking down at the deck. Starting at the tractor pulley, the belt runs from the right side of this pulley to the left side of the tension arm pulley, around this pulley to the left side of the right hand side mower blade pulley, around this pulley, across the deck to the smaller left hand side idler pulley, then up to the left hand side mower blade pulley, around this pulley to the second (larger) idler pulley, around this pulley and back to the left side of the tractor pulley. If you make a small sketch of the deck pulley arrangement it will be easier. Keep in mind some of the pulleys are for the "V" side of the belt and some (The tension arm pulley & larger idler pulley) are for the flat side of the belt. Be sure the belt is not twisted and lays in a continuous circle with the "V" side of the belt on the inside before you start.
from http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=135
Please vote !!
May 12, 2010 | Garden
How do i get the tension of the drive belt to change water pump?
If it is a serpentine belt they all have a tension wheel. It looks like a pulley but is attached to a tension arm and will have a nut on the pulley center. Take a big ratchet or breaker bar and push/pull on the pulley arm to release the tension. Don't pinch your fingers. The same process to reposition the belt. Look at how the belt goes around the pulleys before removing to not get confused on putting the belt back.
Mar 11, 2010 | 2005 Dodge Grand Caravan
Need to replace drive belt on cutting deck and
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from coming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Oct 24, 2009 | Garden
Do you have a diagram on how to install a serpentine belt on a 1994 Chrysler LeBaron?
1994 CHRYSLER LEBARON - V6 3.0L 2972cc 181ci GAS FI N 3
Open the hood, the diagram for the serpentine belt is on the cowling.
From DAYCO Catalog
Belt Routing Diagram (Alt., P.S., Idler & Tens.)
From comments to other users and Lebaron Owners; for remove, starting at the alternator pulley and going clockwise around the pathof the belt, the belt drops down and forward and goes under the idlerpulley, continues forward and less steeply downward and goes around thecrankshaft pulley clockwise, rises rearward going over the top or thetensioner pulley counterclockwise, then drops down and around the powersteering pump clockwise and rises to go around the alternator pulleyclockise (which is where I started the description). To loosen thetension to remove the belt, or to give you slack to install the beltwithout having to force it over a pulley while under tension you rotatethe tensioner pulley arm around its pivot clockwise according to the'94 shop manual. It doesn't show by what means to effect this rotation,but in the earlier manual I have ('89) it shows there to be a 1/2"square hole in the tensioner arm into which you insert a breaker barwith a 1/2" square drive which gives you the temporary lever to rotatethe tensioner against its spring action. I assume there is a similar1/2" square hole on the '94 you are working with. Interestingly,between '89 and '94 the idler pulley was added, and the requiredrotation of the tension arm changed from counterclockwise to clockwiseto relieve the tension."
I think this will help you get the belt on. Good luck.
Oct 13, 2009 | 1994 Chrysler LeBaron
Cant find 97 ford taurus serpentine belt diagram
Drive Belt Replacement ani_caut.gif WARNING: IF EQUIPPED, DO NOT ALLOW DRIVE BELT TENSIONER (6B209) TO SNAP BACK AS DAMAGE TO DRIVE BELT TENSIONER OR PERSONAL INJURY COULD RESULT.
NOTE: Minor cracks in the V-grooved portion of the serpentine drive belt (8620) are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
NOTE: Conditions requiring drive belt replacement are excessive wear, rib chunk-out, severe glazing, frayed cords or other conditions. Replace any drive belt exhibiting any of these conditions.
NOTE: When installing drive belt on pulley, make sure that all V-grooves make proper contact with pulleys.
Drive Belt, Serpentine—Except SHO
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP FROM DRIVE BELT TENSIONER OR PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise on 3.0L (2V) and 3.0L (2V) FF, rotate the drive belt tensioner counter clockwise on 3.0L (4V) to remove drive belt from pulleys. Make sure spring keeper engages into slot.
    Drive Belt Tensioner—3.0L (4V)
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner).
  1. Rotate drive belt tensioner as described under the removal procedure and install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys. Make sure spring keeper releases or improper belt tension will occur.
    Pulley, Routing—Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
    Item Part Number Description 1 10300 Generator 2 6C348 Idler Pulley 3 3A674 Power Steering Pump 4 19703 A/C Compressor 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 8501 Water Pump 8 8620 Drive Belt
    Pulley, Routing—Accessory Drive Belt 3.0L (4V)
    Item Part Number Description 1 3A674 Power Steering Pump 2 8501 Water Pump 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10300 Generator
3.4L SHO Engine
Removal
  1. Remove the right front wheel and tire assembly. For additional information, refer to Section 04-04.
  1. Remove the inner fender splash shield.
  1. Remove the alternator shield.
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE WRENCH DOES NOT SLIP FROMDRIVE BELT TENSIONER OR POSSIBLE PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 3/8 inch ratchet on the lifting lug, rotate drive belt tensioner counterclockwise (upward) and engage spring keeper. Remove drive belt from drive belt tensioner.
  1. Lower vehicle.
  1. Remove drive belt.
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner ).
  1. Raise vehicle on hoist.
  1. Rotate drive belt tensioner , as described under Removal procedure and install drive belt over drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys. Make sure the spring keeper is released or improper belt tension will occur.
  1. Install the alternator shield.
  1. Install the inner fender splash shield.
  1. Install the wheel and tire assembly. For additional information, refer to Section 04-04.
    Pulley Routing—Accessory Drive Belt, 3.4L SHO
    Item Part Number Description 1 3A733 Power Steering Pump Pulley 2 6B217 (RH) Idler Pulley 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10346 Generator 8 6B217 (LH) Idler Pulley 9 6B217 (Center) Idler Pulley
Drive Belt, Water Pump
Removal
  1. NOTE: If removal of the water pump drive pulley is required, refer to Section 03-03.
    Rotate drive belt tensioner clockwise by hand and remove drive belt from drive belt tensioner .
  1. Remove drive belt from water pump drive pulley and water pump pulley.
Installation
  1. Position drive belt onto water pump drive pulley and water pump pulley.
  1. Rotate drive belt tensioner clockwise by hand and install drive belt over top of drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys.
    Pulley Routing—Water Pump Drive Belt
    Item Part Number Description 1 6B209 Drive Belt Tensioner 2 6A312 Crankshaft Pulley 3 8501 Water Pump 4 8620 Drive Belt
Jun 01, 2009 | 1997 Ford Taurus
Belt Removal and Replacement
No.  The motor and pump assembly need to come off.
   There is 4 1/2 inch bolts that hold this assembly to the main mechanism.  2 on top and 2 on bottom.  Work belt off bottom pulley on transmission and then remove these bolts.  Turn motor over and remove 3 torx screws holding pump to motor.  Install new belt then reinstall pump with 3 screws.  Reinstall assemblt to mech.  Pu top 2 screws in first then bottom 2.  Be sure belt goes on left side of black plastic idler pulley.  Work belt around transmission pulley.  You can press on opposite end of idler pulley arm to loosen belt tension.  Make sure belt is on all pulleys before testing.
Oct 18, 2007 | Amana ALW480DA Top Load Washer
Garden Logo
26 people viewed this question
Top Encore Garden Experts
Roland W VanLue
Roland W VanLue
Mike Carew
Are you an Encore Garden Expert? Answer questions, earn points and help others
