Question about Thermacell Mosquito Repellent Appliance, Olive, 12 Hour
After installing new butane cart. tmra wont relight.tried 3 butanes same results
I used my thermacell mos.rep app once .used all butane; let cool ;put away. a few days later put in new butane ;cant get it to light.can see blue spark but cant hear gas.tried 3 new butanes same results.what is wrong?
2 Suggested Answers
SOURCE: I have my daughter's thermacell
I work for thermacell. Just give us a call or email and we will fix it for free.
Posted on Jul 03, 2011
Can i refill conair butane cartridge
There are two videos on YouTube on the subject. Before you start, remember neither the Fire Marshal nor your insurance company will be happy with you when you burn the house down.
How To Refill Thermacell Butane Cartridges Cheap Save Money
How to refill thermacell butane cartridge the easy way Save money
Feb 27, 2015 | Conair Instant Heat Curling Iron, Model...
Why does the curling iron not stay on and get hot
You have lost a soldered connection on the Circuit Board and it is time to throw it away for your own safety
Jul 17, 2014 | Thermacell Conair Cordless Curls Butane...
My patio heater will light and run for about three to five minutes then shuts off, I can wait a few minutes and relight and it will do the same thing.
Hi, This can be caused by using butane during cold nights. Butane will start to freeze on cold nights but propane will work up to -6 . If already using propane then the most likely problem will be a worn thermocouple, these are consumable items. Found this site very useful, patio heaters problem solving.
Sep 19, 2011 | Napoleon Lifestyle Collection Bullet Model...
I have a small propane reddy heater with an electric ignitor if power is out can i manually light it
Yes, you can. Use either a butane grill lighter or a long stick match. Make sure the control knob is in the "light" position and the wick is in the right position. Light the long stick match or butane grill lighter, press the control knob in and while holding it in, touch the flame of the match or butane grill lighter to the wick and the wick should ignite. Once it ignites, quickly remove the match without knocking the tip off into the heater.
Jan 31, 2011 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Bought mini butane soldering iron today filled with butane and used it. It was getting low so i put more butane in it and now i can light it. please help
When you fill the soldering iron with butane you must have it turned so the butane can is held upside down. Liquid butane must be able to flow into the iron. It's most likely that you held it upright and even though gas butane would have flowed in it would not be enough to light it. Only fill it outdoors.
Oct 05, 2010 | Radio Shack Welding Tools
My Pyropen WPA2 will not ignite I have changed the gas ,it has Butane UN1950 in now and is Half full
Does it spark?
Does the butane come out?
How old is it, and how much has it been used?
Did you put cheap butane in it at some point?
Sep 10, 2010 | Weller WPA2 Pyropen Professional Self...
Dunill lighter - how do I fill it with butane?
  1. Ignore that other load of tosh.
  2. Do not refill your lighter immediately after using it. You should allow enough time for the lighter to cool off.
  3. The flame height adjuster on the bottom of the lighter should be set to minimum by turning CLOCKWISE with a small screw driver. The smaller, usually Phillips head, screw is for dismantling the lighter and should not be touched. The adjusting screw is a larger screw with a standard (slot) head. Some lighters come with a key to turn the adjusting screw. Some models have an adjusting wheel that requires no screwdriver. Please DO NOT FORCE the adjusting screw. If it is hard to turn in one direction this most likely means that the adjustment screw is already at the (-) or (+) limit. Try turning the other direction.
  4. Push the refilling valve with a screwdriver to let out the air inside until no hissing sound is heard. Hold the lighter away from your face. Air inside the fuel tank prevents butane gas from being injected into the tank and causes the lighter to malfunction.
  5. ALWAYS refill the lighter in an upside down position to avoid injecting air into the lighter.
  6. Shake the butane gas refill can, press the stem of the refill can directly onto the refill valve on the bottom of the lighter. Keep them in a straight position and let the gas go into the lighter for about 5 seconds. Repeat for a shorter period if needed.
  7. Allow 3-4 minutes to let gas and lighter components reach room temperature.
  8. Turn the flame adjuster counter clockwise to reach the desired flame height.
  9. Hold the lighter away from your face and body and ignite it carefully. If there is no flame, repeat the refilling process.
  10. If you experience gas leakage with a hissing sound while refilling the lighter, either you are not holding the lighter and gas can in a straight position or the stem of the gas can is not suitable for the lighter. In this case you need to use an adaptor which is usually supplied with the gas can.
  11. Premium butane is required to ensure optimum performance of your lighter. Lighters require the cleanest butane available at a pressure of 45 psi. Recommended using Premium Triple Refined Butane Gas that are packaged in 10-13 oz. cans with a metal fill tip nozzle. Non-premium butane with plastic fill tip nozzles are not recommended as they may cause inconsistent ignition and performance. Impurity of the gas can cause clogging of the burner valve or malfunctioning.
    WARNING: PLEASE, ALWAYS KEEP YOUR LIGHTER AWAY FROM THE REACH OF CHILDREN. USE COMMON SENSE IN HANDLING YOUR LIGHTER.
    Troubleshooting: If you are having problems with your lighter, make sure that:
    You are holding the lighter upside down while refilling. If you did not hold the lighter upside down, there will be air inside the butane tank. You will need to let the air out and try refilling again.
    The flame height is properly adjusted.
    You are not using cheap or incorrect fuel.
    There is no dirt or debris in the lighter. Try blowing forcefully into the top part of the unlit lighter.
Dec 15, 2008 | HHP 12V Cigarette Lighter Adapter (for the...
Thermacell Mosquito Repellent Appliance, Olive, 12 Hour Logo
50 people viewed this question
Top Thermacell Home Experts
Donni Steen
Tom Chichester
Are you a Thermacell Home Expert? Answer questions, earn points and help others
