Question about Tag Heuer Grand Carrera Automatic Chronograph CAV518B.FT6016 Watch for Men
How to starts the seconds hand
Seconds hand stuck during setting of date . I shake it withour dropping the watch but no results came out it remain stuck
SOURCE: My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch.  Change the battery, and see if the problem goes away.  If it does not, then it could be a problem with the stepper motor, which will require a watchmaker.  Of course all of this is dependent on the assumption that your watch has a quartz movement.  If it is an automatic, or mechanical you have bigger problems.
Posted on Oct 20, 2007
SOURCE: Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)].  Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2.  You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3.  Cheers!
Posted on Jan 10, 2009
  • 4 Answers
SOURCE: watch second hand
I had the same problem with my Tag. Same 4 second jump. It's definitely the battery. I'm surprised at only 3 months, but maybe it sat a while in the display case. Mine was over a year and a half.
Posted on Feb 16, 2009
  • 6 Answers
SOURCE: seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
Posted on May 13, 2009
Bob Gemmell
  • 209 Answers
SOURCE: Watch was running fine (auto) stopped in middle of
Unscrew the crown and pull out gentle until it clicks outwards twice as if you were going to reset the time and then push it back in and try shaking gently to start the second hand
Posted on Jan 23, 2010
How to seconds hand
Hi Johar,
I will advise you to contact your manufacturer to avoid warranty void due to damage during the process of setting it. Try the link below.
Contact Us TAG Heuer
May 09, 2014 | Tag Heuer Grand Carrera Automatic Calibre...
Tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 | Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
    mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
    Aug 03, 2010 | Guess 17558L1 17558 Watch for Women
    Why isn't the second hand on my Wenger Commando SR not working? The red seconds hand is not moving. The small seconds counter of the chronograph works and the minute and hour hands work.
    The large seconds hand will remain at 12 unless you press the upper right button to start it. Pres again to stop it and press the lower button to reset it. The small seconds hand that always runs is the seconds for the time. The large seconds hand is for the stopwatch function. If you like to have it running all the time just start it and leave it running - it won't harm the watch.
    Jun 02, 2010 | Swiss Army Wenger Commando 70725 Wrist...
    HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
    This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
    A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
    This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
    Count-down, Racing Timer and Alarm features
    ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
    One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
    Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
    The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
    Superb performance
    Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
    When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
    Specifications
    Calibre: ISA 8270 Yachting Movement
    Size 11 1/2’’’
    Swiss Made quartz movement, 9 jewels
    6 hands, 2 counters, 3 pushers
    Hour, minute, small second at 2H counter
    Date window at 6H
    Count-down (max. 10 minutes)
    Racing timer (max. 96 hours)
    Alarm (12 hours)
    Technical information
    Diameter: 25.60mm
    Movement height: 4.60mm
    Height of stem and pushers: 2.25mm
    Jan 15, 2010 | Watches
    Need instructions on National Geographic Men's watch #NG010GYSK
    go to Buliva web site and look for the chorograph 561/598
    FEATURES
    1. Hours, minutes, seconds and date display.
    2. 60 minute Chronograph (CHRONO) with minutes and
    seconds display.
    3. 24 hour hand, permanently synchronized with the normal
    12 hour hand.
    A. SETTING THE TIME
    1. Pull the crown out to position “3” (See diagram). If the crown has
    a “screw-down” lock, then unscrew the crown lock first by turning
    the crown toward you, then pull it to position “3”. Do not forget to
    screw the crown back “IN” after all setting is completed.
    2. Turn the crown towards you (hands moves clockwise) until the
    date changes at approximately midnight.
    3. Continue turning the hour and minute hands to the correct time.
    If it is afternoon you must go past 12 o’clock again (noon) to set
    the correct time.
    4. When the correct time is set,push crown back to position “1”.
    B. SETTING THE DATE
    1. Pull crown to position “2”(See proceeding diagram).The watch
    will continue to run.
    2. Turn the crown away from you until the correct date appears.
    3. Once the date is set, push the crown back to position “1”.
    Note: Do NOT set the date between the hours of 8:00 PM and
    3:00 AM.This would not damage the watch,but the date may need
    to be reset later.
    C. CHRONOGRAPH (CHRONO) ADJUSTMENT
    If the chrongraph second hand is not positioned at the proper
    starting position (12 o’clock or “zero” position), use the below
    procedure.It does not need to be repeated unless the watch
    receives an impact sufficient to move the hand out of position, or
    the Battery has been changed.
    1. Pull crown out to position “3”.
    2. Push button “A” to move the Chrono Second hand (long hand) to
    the “0” or 12 o’clock position. Each button push will move the
    hand one step – BUT holding the button down will advance the
    hand rapidly.
    3. Push crown back to position “1”.
    D. USING THE CHRONOGRAPH (CHRONO)
    Note:
    The maximum chrono reading is 60 minutes, However the
    chrono will continue running once 60 minutes has passed. The
    resulting one hour periods may be added together mentally to keep
    track of longer periods.
    For example – If you know that approximately one hour has
    passed since you started the chronograph, and the chrono reads
    25 minutes, then you know that the chrono has been running 60
    minutes plus 25 minutes, which is one hour and 25 minutes.
    1. Push Button “A” to start the chronograph. Push button “A” again
    to stop the chronograph.
    2. Push button “B” to return the two chronograph hands to the
    “Zero” or starting point.
    3. The Chronograph can be stopped and started again
    (Button “A”), repeatedly, to “ADD” times together.
    BOOK NO. 561/598 Chrono FS00/01/10
    Watch Setting Guide
    4/2007
    Feb 13, 2009 | Bulova Watch
    How do you set and deactivate the alarm function.
    I did find two authorized dealers:
    www.kenmarwatches.com
    www.princetownwatches.com
    Contact both and request users manual fur your specific model. They must be able to help.
    Jan 05, 2009 | Bulova Watch
    How to set watch
    I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
    2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
    Apr 02, 2007 | Kenneth Cole RK5034 REACTION
    Open Questions:
    Tag Heuer Grand Carrera Automatic Chronograph CAV518B.FT6016 Watch for Men Logo
    15 people viewed this question
    Top Tag Heuer Watches Experts
    Jimmy Accardi
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
