Question about LTL Home Products Pinecroft 15W in. Louvered Wood Shutters
Can water sealed product be painted - LTL Home Products Pinecroft 15W in. Louvered Wood Shutters
  • 15,557 Answers
Depends on what sealer was used. If it is silicon based or has high residual oil, then the answer is no.
Posted on Aug 27, 2014
Used filler for filling nail heads rubbed back next day perfect two weeks later painted wattyl undercoat water base and filler went soft
The wood filler, a water based product, pulled the water out of the latex paint and softened. To preclude this in the future, you can cover these repairs with shellac or another sealant to provide a barrier between the filler and the paint. Spray shellac is available in hardware stores, and is used on water stained ceilings before repainting.
May 20, 2015 | Timbermate Wood Filler Water Based 8-oz...
Hey james miller..... . . how have you been?
Really Travis there are automotive products that cost the same and are made for cars
Oct 07, 2014 | Cars & Trucks
I am facing the RV Roof leaks and does not know the solution?
Hi, There is a product called "White Lightning" that is a paint on application for Aluminium roofs on RV's. There is also a product that is a rubber paint on application for RV's as well...don't know the name. If your roof is anything but rubber, I'd recommend a SOLVENT based product, much more durable in my opinion. I had a 34' motorhome with a leak along the canopy rail and I used a solvent based building caulking product used when putting down plywood flooring in homes to stop any squeaking, and it was great, acts as a glue as well. Can't recall the name, PCL Professional, something like that. You need a caulking gun to apply it, comes in a large tube. Hope this helps you stay dry !!! Cheers, Gary
Apr 07, 2014 | Blinglights Trailer RV Camper Mobile Home...
I want to strip the concrete floor that I use jasco seal 6 years a go do you have any product I can use .
  • 1 Make sure that the surface of the concrete is cleaned thoroughly. Remove stubborn dirt or stains with a mixture of one part degreasing cleanser and two parts water. Rinse the concrete well and wait 48 hours before continuing.
  • 2 Use a large paintbrush or a long-handled paint roller fitted with a fine-nap roll to coat the entire concrete surface in a thick layer of soy-based or other environmentally-safe chemical stripper. Allow the stripper to eat away at the sealant for 10 minutes, scrape up the peeling sealant with a paint scraper or putty knife. Clean up all of the debris.
  • 3 Rinse concrete to remove all of the stripper. Let the concrete dry 48 hours. Apply the new sealant or the finish of your choice .
  • Oct 21, 2013 | Jasco Wet Look Cure Seal 0613-GL Set of 4
    I painted a section of my garage floor with a cup of paint 1/4c oil base acrylic mixed with 3/4 c water base latex...will it ever dry thoroughly? it is drying slowly and is really sticky. will I just have...
    did you ever try to mix water with oil? what was the result? are you sure that you can cross the street without adult holding your hand?
    unfortunately you need to remove all that paint, just drop few shovels of fine sand over, and scrape it... sand will adhere to the tp surface of the pain and will allow you to scrape it. after you scrape it off, use any degreaser or similar product to wash reminder off, leave it for few weeks to dry through and then in small patch try if it would accept latex pain, roll it very, very thinly and leave overnight, if it is dry (solid dry) after 24hrs and do not peel off, you can then use this paint on the rest of your garage floor.
    now, i would advice strongly against painting garage floor with any paint except concrete paint (they are usually water based with strongly alcalic ph), and after that use concrete seal. this should give you long lasting surface, sealed from oils, dust, water and whatever contaminant you can imagine in the garage.
    Sep 12, 2013 | Sherwin-Williams Best Look Latex Garage...
    My paint dries to fast, what should I do?
    Acrylic paint depends on time, temperature, humidity, paint thickness, air-flow and absorbency to dry.
    Reeves Complete Acrylic Painting Set
    Oil colour
    paint takes long time to dry than other media and it allows to think and it also provides the flexibility for changes.
    Williamsburg Handmade Oil Color Paint Alizarin Crimson 37ml Tube
    Feb 03, 2013 | Crafts & Hobbies
    I have titan 440i and it has very low pressure when i swich it from prim to spray keeps running
    When you switch it from prime to paint and it's still running:
    - If paint/water continues to come out of the prime tube, your prime valve isn't seating properly and needs to be replaced.
    - If you get a little pressure at the paint gun but it is surging, your packings, most likely the lower set, are damaged and letting most of the paint leak back past them. Packing/seal kits are available for your machine. Use all parts in the kit and grease/lubricate all of the parts well. Inspect the piston and cylinder for scoring or pitting that can damage new seals. They should be mirror smooth for proper operation and life of the seals.
    Oct 28, 2012 | Titan Impact 440 Skid Airless Paint...
    I just want to know what is water base paint and how its used & what material are used before painting car. thank u
    the basic shell of the car is cathodic dipped,then painted with a filler/primer before water based paint is applied,the final coat is dried by radio waves(really)any excess is recycled back to the paint plant ready for the next car.NO solvents are used in the whole process.YOU CANNOT BUY THIS PAINT.it is very similar to normal emulsion paint,although it will not dry in the air,it has to be heat dried/sealed.(in an oven)(check out you tube bmw z3)
    Mar 29, 2011 | 1995 Volkswagen Jetta
    How to clean my oven
    There are numerous products specifically produced for interior cleaning of ovens.
    There are those that you spray on, and others that you use a brush to paint on..
    The important thing to remember is that you do not put any on the oven liners at the sides,or let it get onto the paint work or the rubber seals ,It is also o/k to use it on the oven door glass. Instructions for use on all these products is to be found on the product packaging.
    Plz rate my solution.
    Thanks.
    Jan 15, 2009 | New World G90m Gas Double Oven
    LTL Home Products Pinecroft 15W in. Louvered Wood Shutters Logo
    742 people viewed this question
    Top LTL Home Products Hardware & Accessories Experts
    Gene Haynes
    Hippy_dd
    Are you a LTL Home Products Hardware and Accessory Expert? Answer questions, earn points and help others
