Question about Lightning Audio Car Audio & Video
New amp wont turn on - Lightning Audio Car Audio & Video
My car wont start,how can i fix it?
Check for obd codes & diagnose them
Jul 30, 2014 | Vauxhall Astra Cars & Trucks
1997 honda civic died on the road wont turn over
Start with the battery unless fairly new & have that tested
Next turn key on & listen for fuel pump
It may run but not have pressure or volume
Check fuel pressure at motor with a gauge
Any light on dash & you checked for codes
didn't you? What are they?
Turning over & Starting are two different things,
don't use them together,different systems there
Oct 03, 2012 | Honda Cars & Trucks
Why wont my htc freestyle turn on
my htc freesyle wont turn on like what so ever, so i decided to plug my charger in it & i press the on button & it will turn on but the only thing that happens is it will keep flashing "oops an error has ocurred restarting..." & it will keep popping up & then when i disconnect the charger it will keep popping up for at least 10 minutes & then it will stop. can you help me figure out what to do, instead of getting a new phone?
Mar 28, 2012 | HTC Freestyle Smartphone
My 2000 gmc just shut off while driving
check fuel pump relay, is fuel present at motor
Sep 15, 2009 | 2000 GMC New Sierra 1500
I have 91 4 runner new battery & alternator & new starter
did you check all the fuses and the main fuse under the bonnet try to give thr starter a few taps with hammer not hard if starts then it is brushes in starter ,does light come on on dash if you put key in on position
May 17, 2009 | 1988 Honda Accord 4 Door
Amp wont turn on
Double check all of your connections. I know this same problem has happened to me and come to find our that all the problem was the fuse blew that is connected between the radio and amp. Also check you battery connection. Corrosion on the power cable will also cause it to have a bad connection.
Mar 15, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Blown amp
hi, try connecting the power b+ and gnd and remote turn on cables only (dont connect rca input or any spks), if amp doesnt turn on you will have to take in for repair. no need to buy new amp, coz problem could be a burnt pcb track or even a faulty remote or FET circuit.if amp turns on then connect other cables slowly and monitor the power lite as you do connections. you may have a faulty spk load that will cause amp to stay off or in protection mode. cheers
Jul 22, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Cant get 4000 watt lanzar amp turned on
it sounds like the posotie side of your amp is bad or the soder point is broken
Mar 03, 2007 | JBL S120PII Subwoofer
Car Audio & Video Logo
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Richard Lukszys
Richard Lukszys
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
