Question about Olivetti Lettera 25 Typewriter
Carriage won't advance - Olivetti Lettera 25 Typewriter
I have an Olympia Progress manual typewriter. It seems to be in good working order, well oiled and good action in the keys, except the carriage won't advance when I type. I don't believe the...
try typing with a little pressure on the carriage (push with right hand to the left) if it work like that then the carriage pull cord may be broken
Apr 23, 2013 | Office Equipment & Supplies
The print cartridge carriage is stalled on HP PSC 1610 All-in-one Printer. Carriage won't go all the way to the right because of a small toggle pin.
If you are tec guy. Open flat bed assm.. check the movement of carriage assm manually, see the obstruction, check service station.ensure that carriage should move freely..close it & check...
Sep 10, 2011 | HP PSC 1610 All-In-One InkJet Printer
Its not printing
Make sure that you have a good ribbon installed and that the ribbon is advancing as the carriage moves. If the ribbon is not advancing it will only print until the ink has been used up on the section of ribbon stuck in front of the print head. It will also need a new carriage if the ribbon is not advancing.
Dec 21, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
Carriage won't advance with space or letters.
You will have to take this in for service. Bad escapement
Jun 26, 2009 | Royal Office Equipment & Supplies
HP 170 Color Copier Carriage Belt Replacement
My carriage belt has broke is there anyone who can repair it, or how can I fix it. H P Copier Model 170
Feb 04, 2009 | HP 180 Color Copier
Olivetti Lettera 32 - carriage progression problem
Could be the carriage release lever is jammed or worse the escapement dog is broken.
Jul 12, 2008 | Office Equipment & Supplies
Can't move cassette carriage.
hello savvychris
If you can not get to the carriage motor, can you get to the one of the gears attached to the motor or the carriage gear itself. either of these should allow you to release the carriage.
Can you post some pictures of the carriage, this includes front, top, and side shots? what I am looking for is a way to advance the main motor forwards and thus release the carriage locking system.
If possible, if you have the technical documentation, send me a copy of it, I might be able to figure out what is going on for them.
Thank you,
Shuttle83
Jul 05, 2008 | Televison & Video
IBM Wheelwriter 5--Carriage advance problem
Try code (lang) key either the X or L depending on when it was made
DickyO
Dec 31, 2007 | Lexmark Wheelwriter 5 Series II Typewriter
Olivetti Lettera 25 Typewriter Logo
65 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
