Question about Acer X203H bd Monitor
Problems hooking up my Acer lcd monitor to my charter cable box.
I want to use the extra monitor we have as a TV with the charter cable we have. It is HD. I bought an adaptor cable that is hdmi on one side (because that's all the cable box has) and DVI on the other side (for the monitor) on amazon. When I plug it in the screen bounces around with the message 'Input not supported'. I cannot push the menue button on the monitor because it reads 'no cable connected' when nothing is plugged in. (In case you were going to suggest I somehow change a setting in the menu.) Please help!! Also, I have other cables of all sorts laying around. Could I splice the wire and use the hdmi for the cable box splice in the cable that usually goes from pc to monitor (the one with three rows of little holds)? Just a thought.... I've been searching the internet quite a bit and cannot find a solution. I've seen some talk about the fact that the cable box is HD and the monitor may not be; however, what do you DO if that is the case?
5 Suggested Answers
SOURCE: connecting dvi cable straight to acer monitor
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Posted on Jul 28, 2008
mediarich
  • 188 Answers
SOURCE: Acer X243w monitor as a TV Pic great but "not supported" box
My assumtion is that the monitor is not displaying in 1920x1080 but has defaulted to a resolution that it can handle so as to display something. Step down the resolutions on the monitor until the gray box disappears. If you're satisfied with the picture your watching then hopefully you will be happy when you find the resolution the monitor is actually displaying.
Posted on Sep 20, 2008
  • 3 Answers
SOURCE: Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Posted on Jan 30, 2011
budmrtn
  • 11361 Answers
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 31, 2011
Samsung hdmi problems
There should a button on the monitor to switch the input. Press it until you see HDMI on your screen.
Jul 31, 2014 | Samsung T220HD LCD Monitor
How exactly hook up a sony PFM-42V1 monitor to a comcast cable box, what extra cables do i need..?
you can use a vga cable to hook up to the monitor then the other end to the cable box.
Aug 10, 2012 | Televison & Video
Tv won't read the cable when hooked to the cable wire without cable box
Hello, Mary -
Your cable TV provider probably requires all TVs accessing the cable service to have their own cable converter boxes.
Note: An extra cable converter box will probably cost an additional monthly fee.
We have AT&T Uverse as our cable TV provider and need a cable converter for each TV.
Jan 12, 2018 | Vizio VW26L 26 in. LCD TV
Walter and Barbara Bradford calling back with additional info. The cable box is explorer 4250HDC.It is hooked to the TV with 5 cable hookup.Also there is the power wire and the cable that goes to the box...
what are you trying to do? to hook up the tv you can use the cable output from the charter box into cable input into the tv (meaning cable as in coax cable) otherwise you can use the colored ones. red white an yellow are rca jacks but the 5 wire you talking about are prob compondent cables which are red green and blue. connect those to the tv and the other red and white ones are for audio to the tv you may have to set the charter box to select which output you are using and the tv to the right input for the rca it will prob be input 1 for the component it will be component 1
let me know if thats what you needed
Mar 17, 2011 | Craig CLC501 15 in. TV
Can i hook my 47inch tv to the monitor
You can't hook you TV to the monitor itself, rather the computer.
If your PC has a wide white connector (DVI) that is supplying signal to the monitor, you could use a DVI to HDMI adapter cable to connect your PC to your TV. This is also possible if your PC uses a small blue connector with 15 pin holes (VGA) by using a VGA cable to connect your PC to your TV.
Mar 17, 2011 | Acer AL1916W 19" LCD Monitor
We have just recently repositioned our Philips Model No. 42PFL7422D/37 Flat Screen TV and thought we had written down the proper wiring set up for connecting to Charter Communications etc. Is there any...
CHARTER BOX
3 CABLES
YELLOW - VIDEO
RED - R. AUDIO CHANNEL
WHITE - LEFT AUDIO CHANNEL
Hook them up to tv's INPUT of the same colors
Then turn tv to input or av channel.
Mar 31, 2010 | Philips 32PF7421D 32 in. LCD HDTV
Acer notebook hook-up to T.V
You can! But you need a modern HDTV. If you have one, simply buy a VGA monitor cable. Hook it up to the laptop, (you can't get it wrong). Then put your TV on the VGA input. Hook up the cable.
If you have a Windows Operating System, right click your Desk Top in a blank area and select "Properties."
Then choose the settings tab. Click the 2 monitor and check box will appear asking to "Extend to this monitor." (paraphrased ... I don't recall exactly what it says).
Check the check box then click "OK" and BINGO ... There it is!
Apr 07, 2009 | Acer Extensa 5420-5687 Notebook
How to covert Starlogic M17ANA into tv screen.
yes a dvi to VGA converter is available they are available online and over the counter at an electronics or computer store
Feb 05, 2009 | Star Logic 17" LCD Monitor
Acer input signal
That is because the resolution is incorrect for the monitor.
Aug 05, 2017 | Acer AL2016W 20" LCD Monitor
Sound
If your monitor have inbuilt speaker, then you need not to plug it, because the monitor cable will work for that. I have ViewSonic 19" with inbuilt speaker and its working without any extra cable or connection.
Thanks
Iqbal
Mar 23, 2008 | Acer AL1916W 19" LCD Monitor
Acer X203H bd Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
