Question about Bosch Nexxt WTMC 6500 Gas Dryer
Blinking lint light - Bosch Nexxt WTMC 6500 Gas Dryer
GLEQ2152ES0 dryer stops after ten minutes and then blinking lights on the right of the side panel. The lights that blink simultaneously.
The dryer is telling you what is wrong with it. Count the number of flashes the drying, cooldown, pressaver and clean filter light are flashing then count the number of times the control/start light is flashing. That will give you the error code number.
Dec 04, 2016 | Dryers
Check filter light blinking will not start only beeps what to do please help
Probably a lint buildup on the sensor. Need to clean the entire lint system. Should be able to remove the plastic frill if the lint filter is inside the drum. Remove the two screws and clean out all the lint then pull the dryer out remove the vent hose. Run a vacuum hose or reach up i to there and pull out the li t. Then clean out the vent hise...a broom handle works if it's a straight shot.
Oct 11, 2016 | Kenmore Dryers
Noticed when laundry room is dark you can see a blinking red light under the area of the lint trap on Frigidaire stackable washer/dryer model FFLE1011MW1. Just curious to what that may be.
I did some research on this. It appears the blinking red light is to indicate there might be a problem. The "blinking" is actually an error code. A certain number of "blinks" is indicative of certain types of errors. This is similar to a cars "check engine light". A car is scanned to get the code, which can help lead to the problem. I found a common source for dryer codes according to the blinking red light here:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134859700e.pdf
I hope this helps :-)
Jan 28, 2016 | Frigidaire Washing Machines
Clean lint screen light keeps blinking
The clean lint screen light is just a dummy light. There is no sensor for that.
If it's giving you a AF error then disconnect the vent and run it. If it completes the cycle then it's your vent. If not it's your thermistor.
Sep 30, 2014 | Kenmore Dryers
Error code CL on Kenmore Dryer
The "Check lint screen" light is just a reminder to check the and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty, it's just a reminder. The "Check lint screen" should turn off as soon as the dryer is started. If it never turns off then the control board would need to be replaced in order for the check lint screen reminder to turn off, however the check ling screen reminder light staying on will not effect the operation of the dryer.
Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Nov 02, 2012 | Dryers
My dryer has worked GREAT...today lights blinking check filter..I thoroughly cleaned the lint filter and cleaned behind and IN lint fliter trap and it still is blinking and WILL NOT let me dry anything....
No there is only 1 filter,typically once a error code is display unlit its clered it wont clear itself.refer to your owners manual to see how to clear the code
Aug 06, 2011 | Dryers
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Ice maker not working andred light blinking
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Refrigerators
Diskjet6122 the light that looks like a tear (right below the X) keeps blinking. Cant get the printer to print after I changed the ink cartridge.
The indicator light blinks, it says you're low on ink in one or both cartridges. If you've changed cartridges and it still blinks, you may have stuck or dirty pins in the cartridge station(s). Use a damp, lint free cloth to make sure the pins are clean and move freely
Jan 20, 2009 | HP DeskJet 6122 InkJet Printer
Bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Feb 28, 2008 | Bosch Dryers
Bosch Nexxt WTMC 6500 Gas Dryer Logo
26 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
