Question about LG 37LG50 37 in. LCD HDTV
V3.35.1code and white screen
My tv just switched from normal tv to a white screen and code V3.35.1, it won't switch off with the remote or by the tv button on the tv, none of the remote buttons work or tv buttons, it will only switch off at the socket
  • 3 Answers
SOURCE: Tedelex EC-PD2000 42" plasma TV
Yes, I had the same problem, it happened after 14 months of my purchase, or just 2 months after expiry date of warranty. But remember they have 60,000 hours warranty on screen and this fault is part of screen (no picture J it is screen problem), I called LG, first they did not accept the claim but soon after I mentioned that I have done many research and this is very common problem due to use of faulty part or unreliable design, and if they don't fix it on their cost I will take legal action, one of the supervisor contacted me and after saying LALALALALALALALALALA accepted to send someone to fix with no cost. But I have found out they did to many others whom take this mater serious so it was not just me alone J They are aware of using faulty part is some ranges of their products and now this common problem appears, LG don’t like it and wants to somehow get away. ((((((((((So don’t let it happen))))))))) some of us paid around $5000 to $7000 when this TV came out, recently price went down to around $2000. CALL THEM and ask FIX or COURT? For sure they fix it for you free of charge J Imagine how much would it cost them to recall all TVs which they know is faulty?
Enjoy
Posted on Jun 08, 2008
SOURCE: LG TV
There is probably a bad capacitor on the power board, I had the same thing happen to my 42LB1DR after 2 years. T.V. would turn on and white power light would blink, no pictue and no sound. If your'e a diy'er, it is not that hard of a fix. Take all the covers off of the back of the tv(UNPLUGGED!!!), then look at all the capacitors on the power board. lcd_repair_4_bad_capacitors_lg.jpg
These are the capacitors, look to see if any of them appear to have a bump on the top of them. They are supposed to be flat, you can also tell if one of them has gone bad if there is an oily substance on the metal cover that was removed. If one of them is in question, carefully remove the board, and take it to an electronics store to have them sotter ?sp on a new capacitor. It ended up costing me around $40.00 to have this done. Good luck and if you are not comfortable trying this, than take it to a repair shop, but I was quoted around $450 to take the T.V. in. No Thanks
Posted on Nov 21, 2008
  • 289 Answers
SOURCE: Looking for the remote control code for LG 37LC3r Flat Screen TV
hi..the remote control that supports ur LG
is Universal Remote Control Inc. Digital R50.
This will definitely suite ur tv.
try this out.
thank u..
rate me..
Posted on Feb 05, 2009
SOURCE: lg lcd tv remote code
Lg lcd tv remote codeTRY ANY OF THESE: 140, 024, 040, 098,043, 259,260, 261
Posted on Jul 27, 2009
HDTV GURU
  • 261 Answers
SOURCE: LG LED 4600 - TV
Do you at least get a blue screen? Usually with no picture you get a blue screen. Try hooking up a DVD Player to it and see what you get... Good luck...Keep me posted ..Sincerely HDTV GURU JAY.
Posted on Mar 16, 2011
Broksonic Flat Panel TV, tried to turn back on TV and Green LED light is blinking and screen pops up a few sec with white and colored lines and the turns off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 21, 2014 | Broksonic Televison & Video
Harmony 890 remote quit working. Screen is normal, fully charged battery, but it just quit
reset the code download from www.fitness.manualsonline.com or www.remotecodelist.com
open the remote control. clean the keypads switch, for dirty, oxide, bad contacts switch, or open use the VOM, see the block diagram, if these switch are NOT o.k they will not send infrared signal to the microcontroller from the receiver.
If this doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 20, 2012 | Logitech Harmony 890 LCD Remote Control
Can't get the tv to switch from cable to antenna mode using a RadioShack remote or the buttons on tv
It sounds that the front panel controls are locked with your tV. You have to unlock it first, if you want to change its input selections. If you cannot select the inputs by using the remote control [I thing you are using a universal remote control], setup the remote control with an other setup code. All codes to remote control won't work with some functions. You have to search and select, which code give maximum functionality with your TV.
Jul 06, 2012 | Zenith SY2569X TV
How do i switch from wide screen to normal screen on my Bush btv663dvdsil using my sky remote which is coded for my tv
Hi there
On your remote there should be a "adjustment" button, push that
and on the screen appears a picture of the different ways you can adjust your screen and choose accordingly..
good luckkolbrun
Jun 10, 2012 | Televison & Video
I need to programm a 1986 sears squareview lx1 tv any codes useing a ge universal remote
A recently bought Universal remote, unless it's a very "posh" (as we say here in the UK!) one - around $250 - won't have been loaded with control codes that old.
Much as you may love your Sears it's manual controls from here on out, I'm afraid, or consider getting hold of the original remote (I assume thats been lost or damaged?) by putting out Want ads for one on free ad websites etc.
- or consider getting a modern flat-screen (and digital) TV.
Excuse me, but unless you're using your Sears TV (in the USA or Canada?) as a monitor for a VCR or other device you won't be seeing any live TV on it by now surely? Since the analogue switch off in mid 2010, or was it 2009?
The Sears at that age, can only have an analogue tuner.
Sep 24, 2011 | Televison & Video
Hello i have a 19 inch LG M197 WDP monitor/tv, when i switch it on the screen is white with a little gray bock that flashes and slowly moves across the top of the screen reading v3.02.0 which i presume is...
I also had an LG M197WDP tv/Monitor with the same problem. It comes straight on when plugged in, but with the blank screen and scrolling version number across the top.
The solution:
1. Use the remote control (check batteries first)
2. Point at the working TV and press either MENU or EXIT
3. Static should be seen on the screen.
4. Switch to standby using the remote, by preesing POWER button.
5. Switch back on using the POWER button.
All should then be working normally
Jun 20, 2011 | LG M197WD-PZ 18 inch LCD Monitor
Hello i have a LOGIX x19/17-usb television, the screen is completely white but i can still here tv sound. This has happened before and a wire was replaced under warranty, however on recieving the tv back...
LCD noy getting video signals. It maybe contact resistance problem, Or you may try different inputs and swich on TV? Switching inputs may get the TV signals thru the lcd?
Jan 03, 2011 | Televison & Video
White screen on TV.
My TV does this too. i know how to remove the white screen but the top will still have power only vo4.52.00 to get rid of the white screen press 'return' on your TV remote (not direct tv remote) then change the input pack to whatever it is it needs to be on to watch your (whatever)
Apr 24, 2010 | LG 32LH30 32 in. LCD HDTV
I m trying to program my RC64 remote for Direct TV and as soon as I press the mute/select buttons in order to put in the codes it says that my remote isn't programed for the TV yet so I cannot press that...
Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
Jan 09, 2010 | RCA DIRECTV Satellite Remote Control
Faulty technika tv
A good way to test if a remote is working is to get a normal phone that has a camera on it.
put the camera option on the phone and point your remote at the camera phone. Press the button you believe to be faulty. whilest looking through the phone. if you see a little white light the button is working fine if not try a few of the other buttons to see if its the hole remote that is at fault.
the way this works is camera phone's dont like IR (infrared) so this will show as a little white light on your camera phone.
if it is the remote you could always buy a sky digibox remote. as the Default code will work your Technika tv. ie volume, channels, power, also the help button will change your source/av on your telly.
Hope this helps
Cheers
Little Dish Fitter
Sep 02, 2009 | Televison & Video
LG 37LG50 37 in. LCD HDTV Logo
57 people viewed this question
Computer Repairing
Computer Repairing
