Question about Black & Decker Auto Tape Measure
How to rewind a tape measure - Black & Decker Auto Tape Measure
    Problem Solver:
  • 11 Answers
You'll need to take the tape casing apart but need special security torx bits to do that (a T-8 and T-9). Once apart (careful, two small springs inside) you can take the tape spool apart and rewind the tape to re-establish tension. Then re-assemble!
Posted on Jun 30, 2016
Stanley tape measure rewind
Spring has stretched now Best get a new one.
Jan 19, 2018 | Measuring Tools & Sensors
I have a Stanley Power Lock 30' Tape Measure with 2' 9" of tape that I cannot get back into the housing, Is there an easy solution to this problem? Advise and thanks,
you can try to pull the tape all the way out and then with a rag lightly oiled let the tape rewind back into the housing if that does not work then you probably need to purchase a new tape. for whatever reasona the spring inside has gotten weak. i use a tape daily and have had this same problem when a tape gets old or abused
Feb 11, 2011 | Stanley 30-305 HI VIS MEASURING TAPE
Tape came out of unit. Can it be put back in and still rewind itself?
Yes, but it is a royal pain. The tape has a slot (some are "T" shape and some are tear-drop) in the end, and this fits on to a tension coil inside the unit. What you have to do is re-coil the spring and reattach the tape to it... that is assuming that the tape did not come out because it broke at the slot. There is no way to find out haw many times the spring must be wound, so it is all trial and error.
personally - I suggest waiting untill they go on sale and picking up a new one. I know that's not the answer you want, but it may be a lot easier.
Good luck.
Sep 13, 2010 | Stanley 30-305 HI VIS MEASURING TAPE
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
VHS tape
is it a specific one particular tape? Or is it that all VHS  tapes that you put into the VCR or Rewinder do not rewind? Do clarify
Oct 24, 2007 | Optical Coating Model 108 VHS VCR
Player - rewind malfunction
I have a trv-58 with the same problem. One way is to press play and rewind while in play mode.Getting back to the first of the tape is a chore.
Sep 24, 2007 | Sony Handycam CCD-TR416 Camcorder
VTR won't play
I would take a look at the loading machanism to see if it is properly loading the tape, usually on these type of machines if the tape is not being loaded properly the tape will not play. The rewind working indicates that the motor is still working so what you may also have is a gear problem, in which you will have to look at the gear system as the tape is loading and trying to go into play mode. This looks more like a mechanical problem then an electronics issue. However I would not rule out have to take voltage measurements to confirm that the electronics are ok (you will need a schematic for this, and a multimeter).
Sep 13, 2007 | JVC BR-DV600U Mini DV VCR
Video will not rewind to beginning of tape.
the clutch gear needs to be replaced . you can order the part partstore.com go by brand and model easy to replace around 30.00 dls .
Jun 20, 2007 | Toshiba V643 S-VHS VCR
Black & Decker Auto Tape Measure Logo
250 people viewed this question
Top Black & Decker Measuring Tools & Sensors Experts
Vuk B
Dennis
frankrome
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
