Question about Xerox Phaser 6600dn Color Laser Printer
I am getting color smudges down the center of my pages when I print - is there a way to clean the roller?
5 Suggested Answers
  • 2072 Answers
SOURCE: lock down
Is sounds like your exit sensor actuator has been knocked off. It's not seeing the paper hitting the exit sensor and shutting down.
Posted on May 08, 2008
  • 108 Answers
SOURCE: Black Prints
The toner might be bad, because the old cartridge is working fine.
Posted on Jul 31, 2009
  • 110 Answers
SOURCE: Blue color appears pinkinsh/now stripes and smudging
Are you using third party ink? make sure your ink is xerox OEM. This will clogg up the inkjets and ruin the print head for ever, If you have always used the third party ink then you might want to get a new print head. . If you have used xerox ink then It sounds like the magenta reservoir has spilled over the cyan. This is caused by moving the printer and not waiting for the cool down procedure. Also you might want to change the print head wiper. If the print head wiper is over used it won't clean the print head properly and what that causes is for ink to build up and causes smudge. also make sure the drum maintance kit is still in good shape. (its the yellow roller on the right side of the printer. Well hopefully this helps .
Posted on Dec 03, 2009
  • 2072 Answers
SOURCE: When I print color, the page has a lot of extra toner.
Start with this
  1. Make sure to set the Print Quality mode in the print driver to "Standard" and the TekColor Correction to "None" before performing the next step. This will allow the job to purge only the problem color. Other settings may cause the printer to use a percentage of the other ink sticks.
  2. Print approximately 50 - 100 pages of the document, as necessary, until the printed color returns to normal.
Next. This is on xerox.com downloads and drivers.
The updated sRGB Display and sRGB Vivid color tables for the WorkCentre will help with the following issues that have been found with the original factory color tables.
  • RGB images contain too much yellow.
  • RGB image red shades are too orange or too light.
  • RGB object blues are too dark or aqua.
  • CMYK objects use the sRGB Display color table when the Automatic TekColor correction is used. After the updated color tables have been downloaded to the WorkCentre, the CMYK objects will use the Commercial Press TekColor correction when Automatic is used as the TekColor correction.
    NOTE: The new color tables will only take affect when using the Enhanced or High Resolution / Photo print quality mode.
To update the RGB color tables:
  1. Click on the [Drivers & Downloads] link under the Product Resources menu on this window to download the updated color tables to a known location on the computer's hard drive. The color table update file is located under the Color Profiles section on the Drivers and Downloads page.
  2. After the file has been downloaded to the computer, send the file to the WorkCentre. See the Related Items below for additional information.
Posted on Jan 07, 2010
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
I have a HP LaserJet 3700n. Color smudges
Its the toner cartridge that is the same color as your smudges.
Feb 25, 2010 | HP LaserJet 3700n Printer
We have a Ricoh Aficio CL3500N. We are getting a
Never clean or touch the Transfer Roller (spongey rooler) unless your using a dry cloth or vaccum as last measure.
Usually the transfer roller sits on a drum/pcu specific to that color. If you can tell which color is sitting on to of the roller replace that drum/pcu.
Jul 15, 2009 | Ricoh Aficio CL3500N Laser Printer
Streaky smudges vertically down middle third of each page
NOPE - don't even try to do this - Replace the entire fuser, these have a film roller and it's not worth trying to rebuilt - replace the fuser and you should be fine, To take the top off is a pain , the fuser sits on top of this Printer so it's difficult- either call a Color Printer tech or buy a rebuilt fuser , I wish i could give you our company info, however, i been informed not too Sorry , fixya.com rules not mine.
Mar 04, 2009 | HP Color LaserJet 2600n Printer
Smudge on left side of paper
It seems like your PCU's are dirty and are picking up extra toner. Take them out and look at the green rollers, any extra finger prints or dirt on them? Clean them with a clean paper towel.
Also, check your transfer unit below the PCU's, that may need cleaning or replacing. You can pull that out after removing both PCUs, turn the little screww and look at it. That can also be cleaned with a cleaning wipe or a damp paper towel. There's a little tab that you can turn to free the rollers (they'll still be a little tight) bu then you can turn the rollers to expose more surface area.
Good luck. Be sure to rate the post if it works for you.
Feb 04, 2009 | Ricoh Aficio CL3500N Laser Printer
I have smudges that appear horizontially in a repeating patter
Hi fpugliese630:
1. Remove the paper tray and look inside the printer on the upper part and you see two rubber feed rollers, (they should be a white color) if they have toner on them that could be one of you problems,you would have to clean or replace them if they are worn.
2. you can run whats called a half test, print any document and while the document is printing open the front cover when you think that the paper is under the toner cartridge so the printer will stop. look at the printed page to see if the mark is there. If the mark is not there than you have a problem with the fuser assemble.
Note*
Make sure that the paper path is clean.
Jan 08, 2009 | Lexmark T632 Laser Printer
HP LASERJET 4250n
This problem is with the fuser. It needs to be replaced. They tend to burn out right in the center leaving a rolling smudge across the page as the unfused toner left on the roller gets printed on the next roll-over.
Jan 06, 2009 | HP LaserJet 4250n Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Smudges on right ride of paper
want the answer to this we have a hp 2600n laser printer and its leaving smug of color on the paper the big wide roller where the page gets printed is smear with all the colors. Is there a way to clean this and what to use so we can fix the problem.
connie petrik mu email address is connie.petrik@att.net please give me a answer to this problem.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
Xerox Phaser 6600dn Color Laser Printer Logo
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
