Question about Sony VAIO VPC-EA36FM/W Notebook PC - Intel Core i3-370M 2.40 GHz Proce
VPC-EA36FM mouse buttons
The left mouse button seems to no longer work although a distinct click can be heard once it is pressed. The right mouse button can be used fine. Is this button assembly replaceable and how do I get the parts. The service manual is $159.00!!
5 Suggested Answers
SOURCE: My laptop left mouse button has stopped working
Common hardware problem. The correct solution is a replacement tracker pad and mouse, however you may be able to get the problem fixed by cleaning under the pad. Either way it requires taking the laptop apart.
WildeFalcon
Posted on Mar 28, 2010
LongPockets
  • 1177 Answers
SOURCE: I have asony cybershot DSC
You seem to have it set to use the smile recognition to fire the shutter. Find this feature in the menues and turn it off.
Posted on Nov 22, 2010
SOURCE: dear , My laptop touchpad with left and right
Try updating the driver from Sony website remember to delete your old driver 1st though then re installing the new one
Posted on Jan 25, 2011
SOURCE: two buttons beneath touchpad are not working
You should clean the button by opening the cover, realign it, and check if the button touches to the board.
Posted on Nov 27, 2011
Left click will not work
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar . Or disconnect the mouse from your computer restart.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Hope this helps.
Jan 23, 2013 | Toshiba Satellite C655-S5123
Loss of control over my mouse.
Hi Arsenal,
My Logitech cordless occasionally does the same thing. On mine it was caused by a build up of gunk over the optical sensor. Once I cleaned it, it functioned normally.
I know it doesn't make sense as far as the buttons. I'm just sharing what worked for me. Hope it works for you.
Best regards
Mike
Jul 29, 2010 | Logitech Cordless Mouse
I've got a optical mouse 3000, and a bunch of batteries in the junk drawer, I'm sure at least one of them has good life in them, but the mouse keeps flashing red....also it seems to work when I right...
The red light is connectivity to the dongle on the PC.
Check your mouse settings in Windows for the left mouse button settings.
Does the mouse move on the screen?
You can try reversing the mouse buttons to see if the button is defective. If you swap the buttons and now right mouse clicks do not work, the button is defective.
Nov 29, 2009 | Microsoft Wireless Notebook Optical Mouse...
The left mouse button on my Studio 1535 no longer works. The right one is fine. Can I fix it or do I need to replace the whole assembly?
Try to configure it as a mouse for left handed persons and see if it responds to your clicks.
In any case you should go to Control Panel, Mouse Properties. By pressing a button, the picture on the screen should show you if it is activated. If it does not then there nay be some hardware problem.
If you do not need the Context menus (right click) try setting the right button as the one to perform the usual click.
But nothing beats a new fancy mouse.
Hope this gives you so solutions.
Aug 28, 2009 | Dell F3534 Touchpad
Right click button no longer working
Go to Control Panel and click on the Mouse icon. When the mouse properties comes up click on Buttons tab and check to see if the Left Button is set to Default. Hope this helps. Bud
Nov 28, 2008 | Microsoft Wireless IntelliMouse Explorer
Logitech downloads for V220 logitech mouse
You can get it HERE. Choose the correct operating system to download your driver.
Jun 21, 2008 | Logitech Cordless Mouse
Mouse has lost its grip! (electrical grip, that is)
ok. i see your having great time using that mouse and you cared that device for several years. Try open your mouse and carefully remove these buttons of your mouse to clean those dirty stuff stacked on those linings( I believe that you haven't done this before, right?). I believe that this will need to clean a bit to give it back on track again.
Feb 23, 2008 | Logitech Cordless Mouse
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Switching between PC's makes the mouse run wild
Sadly, this is a known issue with this series of KVM switches (3 out of 5 on Amazon) and I have not seen or heard of any fix. I have heard of older mice operating correctly but even that seems to be hit-or-miss.
Jun 12, 2007 | Belkin OmniView E Series 2-port KVM Switch
Sony VAIO VPC-EA36FM/W Notebook PC - Intel Core i3-370M 2.40 GHz Proce Logo
62 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
