Question about Xerox WorkCentre Pro 123/128 Printer
Xerox 6605 offline - Xerox WorkCentre Pro 123/128 Printer
Tray 1 has paper but gives error no paper
That's a common issue where the no paper actuator breaks. The part number is 120E33761.
http://www.iteminconline.com/120e33761_120e33761-xerox-6600-actuator-no-paper.htm
Jan 03, 2016 | Xerox WorkCentre 6605/DN Color Laser...
How to reset waste toner
Open the compartiment on the right side of the Xerox 6600 or Xerox 6605. Rotate the orange lock and carefully take out the waste box. Now empty the excess toner in a bag by shaking the unit with the "holes" down. Do this for 10 minutes till all toner is out of the box. Do this outside, it will be messy.
Blow off any residue tonerdust and take a little screwdriver to remove the plastic seethrough cover. Remove the toner behind this cover and clean it with a cloth. Glue the cover back in place and re-insert the wastebox.
You will save you some money, but it is an unavoidable messy solution.
Aug 11, 2014 | Xerox Phaser 6600dn Color Laser Printer
ERROR 024-959
Xerox 6605 paper tray empty error, the paper detect sensor arm and pick up roller get out of place. remove paper detect sensor arm and pull down on pickup roller assembly it should be springy not stiff. once it springs again, put paper detect sensor lever back on, on the right side of that lever gets tucked behind pickup roller assembly. hope this helps. The Magic Man!
May 29, 2014 | Xerox WorkCentre 6605/N Color Laser...
What is the cause and solution of a loud grinding noise coming from a xerox workcentre 6605 when printing
Sometimes when the toners get low on toner you will hear the gears grinding, or if there is an obstruction in the waste toner auger. Also check the drum units to make sure they are turning freely.
May 16, 2014 | Xerox WorkCentre 6605/DN Color Laser...
It suddenly went offline after printing a document. When I turn it off & on again, it manages to print the current job but then goes offline.
Turn off the SNMP option in the TCP/IP printer port Properties
Right-click the printer, select properties
Select port tab, highlight port, click Configure Port
UnCheck SNMP status Enabled.
This fix was given to me from Xerox Tech support.
Jun 22, 2010 | Xerox Phaser 3200MFP/N Laser Printer
Xerox WorkCentre Pro 123/128 Printer Logo
183 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
