Question about Garden
Kubota g18 Vibration coming through sterling wheel at full speed
3 Suggested Answers
  • 133 Answers
SOURCE: need to replace drive belt on cutting deck and
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from coming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Posted on Oct 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: We have a Kubota G18 2001 it looses engine power
It sounds as if the engine is running lean.
Hi and welcome to FixYa. I am Kelly.
This is how to clean the fuel passages in the carb.
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it is not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement and fuel flow.
7. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions. Reassemble connections.
FUEL FLOW IS GOOD
8. BEFORE you install the float bowl inspect the bowl nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it. (carb cleaning 101)
Thanks for using FixYa.
Kelly
Posted on Apr 17, 2010
Vibration from front wheels
Sounds like you need your wheels balancing - take it to an auto shop and have them check it for you.
Feb 17, 2014 | Toyota Corolla Cars & Trucks
Vibration
if your running the kubota diesel at north of 2000 rpm the vibration just might be the governor starting to cut in and making it miss this will produce a noticable vibration but unless your monitoring it with diagnostics equipment you wont be able to detect it by ear
also had one that the flywheel was comming loose that did that as well (it had over 500 hours on it )
Nov 11, 2013 | Garden
Vibration on 2004 Cadillac Deville
If a hub bearing was bad, it almost always would make noise, more so when changing lanes at higher speed. Outer CV joints make a loud low pitched rattle when turning (corners). Inner CV joints raise hell at high speed- bad shake! Sway links affect cornering and clunk when hitting rough patches of road surface.
Is the vibration worse at 65 than at 50? If so, you are dealing with a wheel balance situation. Find an old time front end shop that will check the balance on the vehicle. You will have to turn off the traction control to do this or use an on-the-car wheel balancer.
If you feel it at some low speeds at it comes back at other higher speeds, then you are dealing with tire roundness. Possible more than 1. More common than we would like.
Jul 17, 2017 | 2004 Cadillac Deville
Steerling wheel vibration and shake plus abs light
bad tire, gad wheel bearings , loose steering tie rod ball joints , wheel alignment
take it to a front end specialist for a full inspection
Sep 10, 2017 | 2001 Ford Taurus
1995 honda accord Vibration in engine above 100kms speed need help
Thank you for using Fixya
Vibration might not be the engine itself. This could be coming from the tires. Unbalanced and misaligned wheels can cause vibration when running at a high speed. Have a wheel alignment and wheel balancing first.
Thank you for using Fixya!
Nov 24, 2010 | 1995 Honda Accord
Vibration at low speed
ARE ONE OF YOUR WHEELS BENT? OR YOUR TIRES MIGHT BE THE PROBLEM ,YOUR DRIVE SHAFT MAY NEED TO BE BALANCED
May 13, 2010 | 2000 Chrysler Concorde
Wobbling of car while accelerating
the u joints in the drive shaft. (CV joints on front wheel drive) more strss on the joints when accelerating so they cause the vibration. no stress/load smooth run. Replace the joints and you'll feel a big difference.
Jun 24, 2008 | 1996 Suzuki Swift
Vibration in steering column
if your vibration comes and goes with different speeds, most likely problem is balance in tires/wheels. a bent wheel often vibrates more with higher speeds. if the vibration is stong in the steering wheel, the problem is normally in the front end, if you feel in more in the seat or body of the car then look to the rear end.
May 14, 2008 | 2005 Buick Terraza
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
