Question about Kyocera Cell Phones
Program security code for virgins xtc
Cant get past the program sec code in service menu
The "Default" code is the last four of your phone number. Hope this helps.
Posted on Feb 22, 2010
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
I have a s12/72 spanish version and my chid has put the child lock on and i cant take it off
I got the same problem with the s12 72 greek version.The machine locks with the menu button down pressed for 5 seconds. But it can lock with each program seperately. So if you locked the machine with rinse for example you must select rinse and press menu down for 5 secs.If you cant remember the last program you lock it with test everything and each time keep the menu down.
Aug 05, 2011 | Siemens WFXD8400UC Front Load Washer
I cant program my uverse remote with my 32 inch emerson lcd tv.
Try using the codes for Funai, Daewoo, all the low end China sets.
Dec 18, 2010 | Televison & Video
Xerox Phaser 7750 error code 14 & 15.
try to hold down the on/reset button a few seconds when you power it up ...on most printers this resets them ..about 10 sec it is enough ...
Nov 26, 2009 | Office Equipment & Supplies
I need to Progam a Samsung Smooth cell phone.
To Program any Samsung Verizon Phone:
+Go to Menu > Settings (may be listed as settings & tools depending on software version)
+Press the * Key (to the left of zero / 0)
+Enter the Service Programming Code (a.k.a. SPC, MSL, SEC) This code is usually 000000 for most Verizon phones, but if it was purchased prepaid you may have to get it from Verizon. Try 000000 first though.
+Go to Network Settings
You will now be in the programming menu. Enter the information as it pertains to the field indicated.
+When you have entered all of the programming information, press END.
The device will now reset and save the programming information.
Jul 25, 2009 | Cell Phones
Cant turn service light out
Turn the key to the ignition so the bike is ready to start but DO NOT start the engine. Press and hold the SET button (the one on your left index finger, right beneath the light signal) for about 10 seconds. This way a manu will appear. Press and release briefly the SET button so that you can navigate in the menu and choose the option DIAGNOSTICS. Press and hold the SET button for 10 secs so that you select this option. It will then ask you for a code. The code should be 13432. You can input it by pressing and releasing the SET button until you see the number you want and then by holding the SET button for 10 secs to go to the next number. When you enter the code, press and hold the SET button for about 10 secs. You will then see the diagnostics submenu. Navigate to the option RESET SERVICE and then press and hold the SET button for 10 secs. It will ask if yo are sure you want to reset so select yes and press SET for 10 secs. Exit the menu. I know for sure that 13432 is the code for America and Greece but im not entirely sure that it is the same for every geographic region. If the code is wrong then you should probably ask your mechanic
Mar 08, 2009 | 2004 Aprilia Tuono 1000
Problem with mobile phone
I know these codes:
Panasonic
enter *01763*737381# - master reset (user data, user code) A100, A101, A102,G50, G51, G70, GD55, GD87
press *369#(*) - MENU
press 7, 4, 6, menu, menu - lock menu
press *#9999# - 5 sec after power on - SW version (GD75, GD67, GD87..)
you may need to do a master reset to remove the lock.
please rate this solution for its merits. Thank you.
Jan 23, 2009 | Cell Phones
Child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Jul 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
My lg 32lc7d remote wont program the codes
you don't hold down the DVD button; you need to hold down the MENU and mute buttons simultaneously for 2 secs.
The LG owners manual doesn't seem to list a program code for Sanyo DVD players though, only Sanyo VCRs :(
Jan 30, 2008 | LG 42LC2D 42 in. LCD HDTV
Universal remote control for a toshiba comb tv vcr dvd
How Do I get my Menu button to work for a 26inch Toshiba Lcd flat screen Tv ?
Dec 23, 2007 | Televison & Video
Cell Phones Logo
564 people viewed this question
Top Kyocera Cell Phones Experts
Sue Hale
Level 1 Expert
Shane Martin
Level 1 Expert
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
