Formula for perimeter 30 ft wide by 48 ft long
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
2 times (width plus length).
Posted on May 09, 2014
Convert 264 sq ft to linear feet
Hi Mona:
I'd like to be able to help so will need to clarify the intent of your question. Bear with me while I explain.
- 264 sq ft is a measurement of area.
- Example: a room 11 ft wide by 24 feet long would have a floor area 11 X 24 = 264 sq.ft
- 264 linear ft is a distance measurement, and indicates the distance between 2 points.
- Example: A house that is 66 feet square has a perimeter of 264 linear ft. (4 x 66 = 264)
If you can take this information and apply it to your question, I should be able to give a clearer answer.
Hope this helps
Jun 11, 2015 | Heating & Cooling
If 5 hexagons are put end to end what is the formulas for the perimeter?
Well, if you know the side 'a' of each hexagon it is just a*(30 - 4) = 26a
If you know the diameter of the circle enclosing the hexagon then
a = D/2 as radius = a
Sep 23, 2014 | Computers & Internet
What is the greatest perimeter that a 48 meter squared rectangle could have?
Infinite.
A one meter by 48 meter rectangle has an area of 48 square meters and a perimeter of 98 meters. A one centimeter by 4800 meter rectangle has the same area and a perimeter of 9600.02 meters. A one millimeter by 48,000 meter rectangle has the same area and a perimeter of 96,000.002 meters. A rectangle one micron by 48,000,000 meters has an area of 48 square meters and a perimeter of 96,000,000.000002 meters. Keep making the rectangle skinnier and skinnier without changing the area, and the perimeter keeps getting longer and longer.
May 01, 2014 | Computers & Internet
The base is one of the four sides, since you know that it has to have another side that is the same length you double it. So the base and the top are 30. Now you take the perimeter and subtract that so you have 80 minus 30 which leaves 50. This is split between the sides so one side is 25 and the other is the same. The dimensions are 15+15+25+25
Mar 28, 2014 | Computers & Internet
What is the formula for finding the perimeter of a square box with each side measuring 3 metres
Since a square has four equal sides, the perimeter is four times the length of one side. If a square has a side of 3 metres then the perimeter is 12 metres.
Jan 26, 2014 | Perimeter Pant
P=228 width is 24 ft less than the length
Say length is x.
Width is x-24.
Perimeter is length plus width plus length plus width = 228.
x + (x-24) + x + (x-24) = 228
4x-48 = 228
4x=276
x=69
length = 69
width = 69-24= 45
check: 45 + 69 + 45 + 69 = 228
Dec 18, 2013 | Computers & Internet
What is the surface area and volume for 14ft 12ft 3ft?
If that is a right rectangular prism
Volume =14*12*3 c.f.
For the area here is the formula.
Total area of right rectangular prism =2*A_b +P_b*h
A_b= area of base (take 14*12 feet squares)
P_b is perimeter of base (14+12)*2 =52 ft.
h is the height (3 ft)
Lateral area =P_b*h=52*3 feet square
Add all areas.
Mar 05, 2013 | SoftMath Algebrator - Algebra Homework...
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I need to calculate the number of 55 gallon drums that can be placed in a containment pool that measures 8 ft in diameter, and 2 ft. in height. The containment vessel has to hold 110% of the material in...
Calculate the volume of one 55 gallon drum by using this formula
22/7 X Radius squared X hight of cylinder = Volume of large vessel.
22/7 X 48" (Squared) X 24" = Volume in cu in
100.57 cu ft in large pool = 752.315 US gals.
110% of 50 gals = 60.50 gals
752.315 divided by 60.5 = 12.43 drums
Draw to scale the large poola nd then draw to scale the smaller drums and see if 13 drums fit.
Feb 24, 2010 | RTO Automatic Transmission And Engine Oil...
A pool with a radius of 2.5 metres surrounded by a path 0.8 metres wide what is the perimetee of the pool .using the value of 3.142
You must have been taught the relation between the circumference (perimeter) of a circle, the radius and pi. Use it to calculate the perimeter. It is true for all circular figure.
Depending on what is really asked (the perimeter of the actual pool where you find the water, or the general pool area where no shoes are allowed)
1st case: use the radius that was given.
2nd case: the total radius is the radius given plus the width of the path.
If you do not have a formula for the perimeter that involves the radius, but have one that involves the diameter you can use it too, knowing that the diameter is twice the radius or the radius is one half of the diameter.
As you might have guessed I was not going to make things too easy for you by providing a ready-made answer, but I gave you all the hints that will help you solve the problem.
Oct 11, 2009 | Mathsoft StudyWorks! Mathematics Deluxe...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
