Question about Ariens Zoom 42 In 165 HP Briggs Stratton Zero Turn Riding Mower ()
How can i get a diagram for safety switches on 1999 cubcadet 1641?
I have a 44in Z-force CubCadet-53AA5B6L710 that will not continue to run after the parking brake is let off. I have replaced seat and brake plunger switch. Any other ideas to look at?
Check both safety switches where your steering arms raise they may need to be replaced as well. You can use a jumper wire to bypass them to check if they are the problem.
Mar 16, 2016 | Cub Cadet Riding Lawn Garden Zero Turn...
Belt routing for cub cadet 1641
Easiest way is to remember; flat side of belt goes onto flat pulleys and small V shape goes into V shaped pulleys.
Oct 08, 2014 | Garden
How do you test safety switches on a cubcadet 1050
Disconnect & test for resistance with an OHM Meter the reading should change when you depress the switch , if not than its bad
Sep 19, 2013 | Cub Cadet Garden
I have a CubCadet I1045 mfr 2008. Will crank but not start. Changed plug, and fuel pump. Can it be an override safety switch? How can I tell?
With the Key in the 'ON' position see if you are getting 12V to the Engine Coil.
I think All of the Safety switches are at rest in a 'Normally Open' state. so if you jump a wire between the two connections of the switch, it will jump out the switch.
Aug 25, 2013 | Garden
On a CubCadet MTD pto switch,where does the black wire go at the other end?This is a 13A-212F100 model
I found a parts diagram for your model, but unfortunately, not a schematic that would show the wiring itself. You may be able to figure it out with some patience. There are two circuits that pass through the switch. One has a lead bringing power (+12V) from the ignition switch, possibly via a fuse; another wire takes this power to the PTO clutch. The second circuit is a safety interlock that kills the engine if you are not in the seat when the PTO clutch is active. It may come from the seat switch and go to a kill relay, but there are variations. Tell more about your trouble symptoms and maybe we can figure it out.
Aug 02, 2010 | Garden
Engine starts then shuts down
I would check compression and spark first.
I have often found removing the bowl on the carb and spraying carb cleaner in the orfices etc can fix alot of small engine problems. Just getting fuel is not enough; It need to be the proper mix of air and gas.
Also be sure you have fresh fuel.
Jan 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
CubCadet ZForce 23 50" - runs, but dies when try to move
The safety switch under the seat is faulty and it must be replaced.
Apr 24, 2009 | Garden
Ariens Zoom 42 In 165 HP Briggs  Stratton Zero Turn Riding Mower () Logo
18 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
