Question about Swisher Garden
How do you change oil on a Swisher 60 inch with Briggs and Stratton 27 HP engine
jgwhomeequip
  • 1902 Answers
SOURCE: 31p777 18.5 hp briggs & stratton valve cover leak
Both can cause problems. It is recommend that you do not go on a grade more the 10% for your safety and the safety for others around. But if the valve cover is leaking this can lead to major problems if not repaired on a timely matter
Posted on Apr 29, 2009
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
moretons
  • 155 Answers
SOURCE: oil capacity for 14.5 hp briggs engine
That would be 1.2lt to 1.4lt from empty
Posted on Aug 12, 2009
mowerman1857
  • 389 Answers
SOURCE: timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
Posted on Sep 29, 2009
miket756
  • 2702 Answers
SOURCE: My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Posted on Jun 20, 2010
Testimonial: "Thank you for theinformation. I did suspect it may be the Piston Rings but I always thought you would get heavy smoke from the exhaust if the rings were going??"
My Swisher 60" trail mower, how do I adjust the belt tension idler burning belts up real fast
look in the user manual and it should tell you how tight; looks like the belt is too loose and slipping allot to burn up..
Jun 06, 2015 | Swisher 60 in. 14.5 HP Briggs & Stratton...
What could keep it from cranking?
change solenoid. check for voltage just because it is new it might be bad
Jul 16, 2014 | Swisher T14560 T - 60" Trailmower with 14...
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
I want a manual for the 60 inch tow behind mower with 14.5 hp B&S engine. himark47@gis.net
try this web sight it is one of the largest on line manuel web sight out there. i don't make any promises but they have come threw many times in the past.
http://www.manualsonline.com/?src=12022010
May 12, 2011 | Swisher 52Inch Trailcutter 185 HP Briggs ...
WhaT TYPE OF OIL DOES THE 16.5 HP B&S engine take
Your 16.5 hp Briggs engine takes SAE HD30 weight motor oil. I recommend to use a name brand high quality oil. It should take 48 ounces from a complete drain. If you run this engine when it is cold outside (below freezing) then you can change to a 10W30 oil.
Good luck
Sep 16, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Smaller belt on my swisher pull behind mower keeps breaking
make sure it's not coming into contact with any sharp surfaces
Jun 26, 2010 | Swisher T14560 T - 60" Trailmower with 14...
27 horse power briggs on poulan pro. It smokes,
Very likely, the piston rings are badly worn or stuck. There may even be a small hole in a piston. In any case, you will need a major tear-down to repair this one. This is usually caused by lax oil-changes. It might be better to purchase a replacement engine than try to fix everything that could be wrong with the present unit if you take into account parts and labor. Hope this helps!
May 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
What kind of oil does the 22 hp briggs stratton take
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Stratton Briggs Stratton Intek V - Twin Engine 21 hp oil had white foam in it
The oil is contaminated with water. Change oil and filter, if it has one.
Jun 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
81 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
