Question about Zenith XBV443 DVD Player/VCR
Static from multiple DVD's
Starting hearing static from a DVD. Cleaned the DVD, same problem. Tried multiple DVD's and same problem. VCR produces clear sound. How does one get rid of the static. Is something wrong with the laser? THis started hapenning after my son left a DVD on pause for over an hour.
  • Jennif102 Nov 24, 2007
    hearing static when I play DVDs
  • Anonymous Dec 05, 2007
    Started getting static only when playing the DVDs in my VCR/DVD combo unit (Zenith XBV443). What can I do to get rid of the static?
I know what happened.
Your son was watching a porn flick and decided to pause the dvd when he saw a hot scene.
He was trying to **** off (but couldn't) and left it on pause too long, eventually burning out the unit.
Posted on Jun 13, 2008
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help ยท Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
How do I eliminate 3 minutes of static, that I accidentally recorded from the VHS tape onto the disc. I want to record something after that but don't want 3 minutes of static in the middle of my recording.
besides sitting there to hit stop when the static part starts i would suggest loading the video onto your computer and use a video editing program to edit out the static from your recording - if you load 2nd thing your were going to record you can even put in effects and join them together as a "double feature" if you want
Apr 22, 2011 | Magnavox ZV450MW8 DVD Recorder VCR
My speakers do not work on my system even though i hear static through them??
Static is audio, so the speakers are probably working. What source(s) produce the static (FM maybe)? Have you referred to the manuals for setup and are NOT mismatching speakers and amps?
Feb 28, 2011 | Philips HTS3151D/37 Theater System
Hearing static while the dvd is playing how would i go about cleaning it
I have the Zenith XBV410 (combo dvd/vcr). I cleaned the lens using the Maxell Lens cleaner kit but nothing happened. Then I ran the Progressive Scan Mode and that seemed to do the trick. Word of caution: Progressive Scam Mode is difficult to turn off so would recommend you remove dvd from player, then press and hold the stop button for a min of 5 seconds up until whatever it takes to disablel PSM (Progressive Scan Mode)
Dec 27, 2008 | Zenith XBV443 DVD Player/VCR
My dvd/vcr player has alot of static and lines on the tv
Check and make sure you have the composite cable (5 color cable) connected correctly and you have the NTSC/PAL set to NTSC (north american if applies) If you have a audio out (r/wh) cable into the RGB inputs on the TV, itll knock out a color or chroma channel and itll look strange.
Nov 15, 2008 | Sanyo DVW-6000 DVD Player/VCR
Static in playback of VCR on Panasonic DMR -EZ47V DVD/ VCR combo.
First make sure the cable on the back has the center pin and its in nice and tight.I would also try another VCR on the same line that way you can eliminate that first.Then if that doesn't show a problem it maybe a internal problem with a lose solder joint.Also I was wonder does the horizontal lines appear when you use a prerecorded tape.If it does you may need to clean your heads on the VCR.
Jul 30, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Static while listening to a dvd through the radio or wireless headset
have you tried changing the radio station. I had this problem and just changed the station on the radio remote and the radio itself.
Apr 27, 2008 | Myron & Davis AD-212 Car DVD Player
SD-V592SU: static noise
That's a stumper.
Personally, I have a simular unit and I just leave it on all the time.
Other than that, borrow a DVD or VCR or combo from a friend and see if it does the same thing. At least you can narrow it down to the combo player or the TV.
Dec 26, 2007 | Toshiba SD-V392 DVD Player/VCR
Zenith XBV443 DVD Player/VCR Logo
172 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
