Your code 21 is just telling you that your left sidelight is out. The shaking and juddering is a different issue and needs a pro grade scan tool computer to see which sensor needs replacing.
21
Failure of left sidelight.
Code 95 on your 2010 Vauxhall Astra Life points towards a fault with the airbags; in other words, your airbags require servicing. To know more about the codeson your car and what they mean, follow this link: https://www.drivingtesttips.biz/vauxhall-astra-dashboard-engine-warning-lights-meanings/fault-codes.html
Hi
I have a vauxhall astra 2002 1.6 sxi. Ive just put in a mirror switch as the last was broken when I purchased car. The switch has been tested and is working but the mirrors dont work? Cant find a fuse which is specifically for that. Can anybody help?
Have a coolant system pressure test carried out to find out if there are any leaks in the system also replace the coolant pressure sensor as it may be faulty.
Most units are fitted behnd the glove box a couple of screws in it & under it, and the whole thing will come out.
if it has an adjustable sensor then there could be a small hole with a - + a small screw driver turns it up or down, it could well be one that needs programing via software inother words there is a set up sequence which puts the alarm in programing mode...
It depends on the manufacturer. (WHAT ALARM IS IT?)
