Question about Whirlpool Ovens
How to reset thermal fuse in 6th sense oven - Whirlpool Ovens
  • Whirlpool Master
  • 5,323 Answers
The thermal fuse is not normally reset u have to buy new one
Posted on Apr 09, 2015
2 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: I have an Electrolux double
Hello & Welcome to FixYa
The problem is with the temperature sensor or the door switch. There is no such thermal fuse, you can check this picture for parts, part#37 is the oven temp. sensor that needs replacement. It should read between 1080-1120ohms on a voltmeter if it is fine. Please get back to me if you have any other questions.
Kevin
Posted on Apr 13, 2011
Now to reset thermal fuse forDacar Oven MCS130
A thermal fuse may have to be replaced rather than reset.
Nov 24, 2016 | Ovens
How to reset the thermal fuse
Thermostats are resettable, thermal fuse aren't, they can only be replaced. Good Luck
Mar 08, 2015 | Thermador SC302T Electric Double Oven
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
How to reset thermal fuse on jkp56 double oven
If it has a red button in the middle, push it until it clicks. If no red button, you have to replace the thermal fuse.
Jun 03, 2014 | GE JTP45 Electric Double Oven
Auto clean problem
You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
Feb 16, 2014 | Whirlpool GBD307PR Electric Double Oven
I used the self clean on my oven and now i cant get the oven to work
thermal fuse went out. check the back. some thermal fuses are resetable
Feb 12, 2010 | Ovens
Whirlpool oven stopped working after self cleaning
If the display still works but neither the Bake or the Broil elements wont heat up, it's likely that the Thermal Cutoff has opened and has not reset itself. This is a common problem after self Cleaning.
The fix is to replace the Thermal cutoff which requres you to pull the oven and remove the back panel to get at the thermal cutoff.
What happens is that in Self Clean, both Broil and bake elements are used and the oven gets so hot that the middle skin (between the oven liner and the back panel, where the thermal cutoff is mounted gets so hot the thermal cutoff operates. It should reset itself but sometimes doesn't and then you have to replace it.
Nov 17, 2009 | Whirlpool RBS305PD Electric Single Oven
KEBS 278 DWH6 After self cleanng (Top oven) everything shut down. There is still power to the ovens and I have shut off breaker for a long time to see if computer reset. I read that the problem might be...
The thermal fuse is in back of the oven. This is a design flaw of the oven KitchenAid won't admit. Everytime you use the self clean feature this will happen.
The oven has to be taken out to reach the fuse in the back and replaced. The fuse costs about $40+, but the labor will probably run around $300+ unless you feel confortable doing this yourself.
I am about to replace mine for the 2nd time, good luck!
Jun 13, 2009 | KitchenAid Architect® KEBS277S Electric...
Neff oven u1421 not heating up
If you have an Ohm meter, then test anything you feel is failed. No sense in replacing good parts.
I am surprised that there is no wiring diagram somewhere on the unit, like in the control head, or on the top or back (most units built in the U.S. over the past 30 years have them. Don't know about UK, which is where I assume you are.).
Let me know! The overload on the back should have a red reset button. The thermal fuse has to be replaced if it's failed, and normally when it fails, the control head will not work. It usually does not carry enough current to power the elements.
Jan 30, 2009 | Neff U1421 Double circotherm Electric Oven
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
93 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
