SOURCE: A200T mixer
On the bottom of the planitary the part where you put the beater. there is two nuts. one lookes like a Acorn nut and a thin one above it. By the book the top thin one should be finger tight. Not wrench tight. you need a thin wall 3/4" wrench you hold the thin nut with iot and tighten up the bottom acorn up to the thin one and they lack against each other so not to come losse .on some mixers this thin nut tightend down will mess with older parts and bind the centersahft parts.
SOURCE: How do you change the grease in a D-300 Hobart Mixer?
Depending how old the mixer is they used to use oil,now they use grease.Regardless it sounds like a seal is worn.Where is it leaking from?
SOURCE: How much grease should I pack into a gear box of a...
pack it full the grease seems to find a way to move a way from the gears after a while so you new grease and pack it in
SOURCE: How do I empty and
Transmission has to be somewhat disassembled, grease removed, lower seal should be replaced and then grease added and reassembled. Not that easy to do. Check www.hobartservice.com for your local Hobart office.
