Question about Dell Inspiron 1100 Notebook
Inspiron 1100 will not boot up-suspect power problem
The hard drive went bad, I replaced it. It now seems to be having a power problem. I am trying to find out what is the problem before I get more parts. It doesn't boot up, the cap lock & num lock lights are on or flashing, the light display is not consistent. The lights do not come on when the battery is out, AC power only.It often just tuns itself off, but not always.
I would hook it to an external monitor first to see if the screen is blown.
If it comes on, keep pushing F12 to get the diagnostic screen.
Run a complete test, it will give you error numbers.
Posted on Jun 23, 2009
Will not boot up
Check your bios and see if you can see the hard drive. You may have dropped / knocked it and it may have came loose or damaged. If the hard drive shows up in the bios, it sounds like a mother board issue.
Feb 11, 2013 | Dell Inspiron 1100 Notebook
I'm trying to increase hard disk space on a Dell
Hi.
The Dell Inspiron 1100 is a laptop whereas the Dell Dimension 2400 is a desktop pc.
The hard drives are incompatible because they are a different size, plus the Inspiron only supports one hard drive so you can't install a slave device. The only way to increase hard disk space is to buy a large capacity internal IDE laptop drive or an external hard drive.
Regards.
Jan 01, 2013 | Computers & Internet
Dell Inspiron 2650 will not boot to Windows install CD after UBUNTU Linux installed on machine.
have you went onto the BIOS to make sure that the boot options are correct e.g. CD DRIVE 1st priority?
Aug 06, 2012 | Dell Inspiron 2650 Notebook
My hard drive does not seem to turn on! i.e.-- no light on, not showing up in Finder (I have an Imac) I've changed ports, and outlets... no luck.
either the case power connect died or the whole unit went bad.
you can try pull out the hard drive and put it in another external usb case to see if it will work.
Mar 06, 2011 | Verbatim (96759) 1 TB USB Hard Drive
My HP S3700Y constantly lock up, both while surfing the web and checking e mails? This is the second hard drive, as the first one went bad after only 5 months of use, so I am absolutely beside myself at...
Was a new or a refurbished hard drive was purchased? If new Replace the power supply instead. The power supply can cause hard drive failures even on new hard drives. Never purchase a refurbished hard drive neither
Feb 26, 2011 | HP s3700y PC Desktop
When I woke up this morning, the light is off ofthe Lacie drive and it is not working. I have tried inplugging both to the power and also to the computer. Nothing seems to be happening.
first, check the power supply. If the light on it is of a bright stable green and there are no sound from it, the power supply should be healthy and we will turn toward the drive, else replacing it should fix your issue..
Sometimes, you can smell a "burn" smell near the connectors ar the back if things really went bad and the interface fried. If your drive operates on a smoking environment, you might not notice it as much. Opening the casing and doing a visual exam of the interface to look for cracked chips and black burnt marks would allow us to confirm or not that the interface fried. If it appears that it did fry, verify the hard drives electronic boards for the same signs. If they seem healthy, replacing the interface should get your drive running again.
If there are no sign that it fried, check the power switch to see if the soldering is loose or broken in some areas. Do the same verification with the power connector. If all is good on that side, replacing the power module or the whole interface card should bring power back to the drive.
Regards,
Jan 16, 2011 | LaCie Big Disk 500 GB Hard Drive
Inspiron 1100,screen will not come on at all,is there a way to format the hard drive without seeing what you are doing?Also it will not boost from a XP disc to fix it.Last time i seen the screen it had 2...
You can hook the laptop up to an external VGA monitor and then power on, you should get video externally by default.
If you don't try pressing the FN + F5 key once.
If it wont' boot to the XP cd make sure the boot order is set to boot cd rom / dvd rom first in the bios setup page.
Let me know if you get stuck or have any other questions ;)
Sep 25, 2010 | Dell Inspiron 1100 Notebook
I've got an Dell Inspiron 9300 LCD
Try running diags Fn + Power button see if anything fails
Since you can boot to the BIOS, then the system is posting, so I suspect you have either a Windows issue or a hard drive issue.
If the HDD passes diagnostics, I'd try booting to the XP CD and see if you can press R for recovery console and run the command CHKDSK /R and see if that resolves
Post back with the results
Jul 19, 2010 | Dell Inspiron 9300 Notebook
Seems to have died -- the power light is on (green) but can't hear the disk spinning and nothing shows up on the screen.
Good news and bad news.
Bad news is that usually indicates a failure of the hard drive inside the case or the driver electronics. If you don not hear or feel the drive spin up that can mean the drive is dead or may not be getting any power. It requires the external power to run. You can check that with a volt meter. It is possible that the connection or the internal board has failed as well which would also mean the drive itself could be fine.
Some good news is that you can replace the drive with any 500 or even 1tb sized sata type hard drive fairly cheaply. It only takes a few minutes to open the case and replace the drive.
If the case is bad then you can buy a cheap $20 and up usb drive case and out the drive in there and be up and running again. Usually if you shop around you can do this cheaper than buying a new complete unit.
You can also connect the drive to your pc as a second sata drive.
You have a few options here, but those really depend on what went wrong.
Apr 18, 2010 | Buffalo Technology DriveStation HD-HC500U2...
Good morning. I have installed in my Company a Iomega nas model 450R. This morning after a reboot,it seems it can't find the boot disk and the nas asks for a operating system restore or go back to factory...
It seems that the main hard drive in this server either went bad, had a windows corruption or that one of the internal connections inside this server went bad.
You would need to check on all three of these areas to make sure 1) the main hard drive is functional (which is my first suspision so check the hard drive for errors and if it fails you would need to do a data transfer to a new hard drive). 2) use your windows software to repair the dammaged registry that may have been corrupted somehow (only do this if the main server's hard drive passes its hardware tests).
You would need to run the original os but I would need to know which one you are using to guide you more to solving the regisrty issue.
3) Hopefully tis server has a warrenty and it may need replacing if all else is working.
Try #1 which is the highest supected for failed hard drive issue (remember if discovered that main hd is bad you may need to perform a data transfer immediatly and replace with a new hard drive.
any other questions please write back with status :)
Mar 19, 2010 | IOGear Computers & Internet
Dell Inspiron 1100 Notebook Logo
101 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
