Question about Tanaka TLE-600 2.5 hp 50cc [REG] Walk Behind Edger
WHY WOULD A TANAKA TLE-600 EDGER QUIT AFTER 15 MINUTES?
HAVE REPLACED FUEL FILTER, SPARK PLUG, AND CARB.
445 HUSQVANA SAW QUITS
Sounds like fuel starvation, always start with simple things first, replace the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of leaking.
Jan 18, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
Runs good for 2-3 min, then dies
I would try using some solvent to clean the carb. It sounds like the float valve is not moving freely, therefore not letting enough fuel into the carb. Be careful though, solvent can be a bit rough on the engine, so be sure to drain it out of the fuel bowl and replace with the appropriate fuel before starting the engine.
Mar 20, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
PE 550 Poulan weed eater edger. Replaced gas tank that came with new gas lines and gas cap. Runs on full choke but not off of full choke. Also noticed it will run okay with gas cap off. When you...
A bad duckbill vent (the little green thing) inside the fuel cap will cause a vacuum to be created if it is NOT venting to the atmosphere. Odd that all new ones you have used are bad. Maybe try using your old, original fuel cap and the carburetor needs adjusting or at the least; a gaket and diaphragm kit installed. Carb screws are NOT user friendly, thanks to EPA and CARB emissions regulations. You can get onto the heads of them to turn them by tapping a 22 gauge automotive-type plastic wire connector onto the head, and that will give you enough grip to turn them. I would TRY adjusting the carb before getting a kit, but after 2 years or so, a G & D kit is usually needed due to the internals of the carb drying out. If you adjust the carb, this is how the manufacturer says to:
http://www.zamacarb.com/tipspage.html
Sep 06, 2011 | Poulan Pe550 Gas Edger
Forgot to drain the gas last fall and found it had small amount of water in the tank. Drained it out and cleaned the fuel filter, cleaned the carb out and now it starts, but runs only if the choke is on.
I would recommend replacing the fuel filter and spark plug. If this is a 2-cycle engine be sure you are using fresh gas with the proper oil mixture. If your engine has a fuel primer bulb be sure to push it several times until you feel resistance before starting and make sure there are no fuel leaks. Failing that you may need to adjust the carb fuel mixture screws after the engine runs long enough to warm up (1-2 minutes). Check your owners manual for other troubleshooting procedures. Good luck.
May 24, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
My tanaka chain saw wont idle and when i pull the gas trigger it quits or bogs down
clean spark plug and gap, remove air filter and clean, look at the spark plug and tell us what color it is, You may need to adjust the fuel mis to get it to run right or you may need a gas filter. Post here with more information.
Aug 28, 2009 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Put new carb on 86 cr 80 ran fine 4 10 minutes then quit changed spark plug and gas still nothing. has spark dont know how hot also changed manifold appeared to be dry rotting still nothing. even attemped...
for any motorcycle to run you need three things. spark, fuel and compression. i see you've tried to get fuel and spark. if you have spark thats one down. dont pour fuel into cylinder. instead spray tiny bit of brakeclean or carb clean into spark plug hole. i have a feeling if you drained your gas after the carb clean the carb most likely sucked bad gas back up and might need cleaned again. ive seen it happen alot on ols bikes.
Jul 11, 2009 | 1993 Honda CBR 600 F(2)P
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
May 20, 2009 | Garden
Tanaka TLE-600 2.5 hp 50cc [REG] Walk Behind Edger Logo
Top Tanaka Garden Experts
john h
Nick Olsen
matt
matt
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
