Question about Magic Chef Microwave Ovens
Where is the fuse located on a Magic Chef MCO153SF microwave?
There is no power to the unit. It's been this way for days.
MicrowaveSvc
  • 9085 Answers
SOURCE: Replacing the fuse of a MCO160UW
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
SOURCE: magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Posted on Sep 17, 2008
danforddan1
  • 192 Answers
SOURCE: No power !
Check the fuse. its inside . If you need help replacing it let me know I will walk you through it. DFD
Posted on Apr 20, 2009
localwonder
  • 6784 Answers
SOURCE: I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Posted on Dec 23, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
How to find the fuse in 2007 magic chef over the range microwave
It is fused through the house fuse/circuit breaker box.
Feb 09, 2017 | Magic Chef Microwave Ovens
WHERE IS THE FUSE LOCATED ON MY MAGIC CHEF MCO165UW MICROWAVE
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 02, 2015 | Magic Chef Microwave Ovens
Where is fuse located, magic chef mco153sf microwave oven
fuse-located-magic-chef-mco153sf-4e5eoo02uytabw1vwgixtmyx-2-0.jpg fuse-located-magic-chef-mco153sf-4e5eoo02uytabw1vwgixtmyx-2-2.jpg
Cylindrical fuse is located inside a cylindrical casing (approx. 2 inches long), found suspended amongst the wiring.
The fuse is NOT fixed to a circuit card nor another fixed point in the microwaves, as is common with other microwaves.
Apr 13, 2012 | Magic Chef Microwave Ovens
My magic chef microwave, model # iMCO160S,lost power, not during use. I have checked electrical connection and is OK. Do i need to change a Fuse ?
Fuses are a common failure part. If the fuse, you can purchase ceramic types from Electronix: http://www.electronix.com
Sep 03, 2011 | Magic Chef MCD1311ST Microwave Oven
No power at all to magic chef microwave. Checked the outlets working
check the fuse.. the location should be specified in the manual.
Apr 14, 2011 | Magic Chef Microwave Ovens
SERIAL # 20101639 RELEASED 2002 THIS MAGIC CHEF IS USED IN AN RV FUSE BLEW RESET MAIN FUSE MICROWAVE DID NOT COME ON PULLED OUT CHECKED POWER OUTLET AND POWER IS WORKING TO OUTLET CHECKED ON ANOTHER...
most microwaves do have a fuse to protect the power supply .outer cabinet has to be removed and then you will be able to see it . look where the power cord comes into cabinet
Dec 01, 2017 | Magic Chef MCM660A Microwave Oven
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
No power no time orday
Check the fuse, open front of micro, look for paperwork on wiring diagram, this tells all the working parts. Look for fuse, test to see if bad. If good, test all cavity switches there must be a bad one, replace and unit should work.
Jun 16, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
