Question about Zebra Z4Mplus Label Printer
Calibration I have a Zebra Z4MPlus and ever time I load my labels and turn the printer on, the printer loads all the labels on the roll. How can I get this to stop. I can't do my job if the printer doesn't stop at just one label when you first turn it on.
    Scholar:
  • 51 Answers
I think your printer is set to print on Continuos media. If you use gap labels, you will need to set the printer from the menu on NOT CONTINUOS, then save the setting. In some cases the software or driver is the one who controls this setting. So you will need to change directly in the printer driver. You will find this option on the General tab (click Properties then) and Advanced tab (click on Printing Defaults). There you will have a list with printing parameters like speed, darkness, media type. Adjust as you need to fulfill your request. But first change directly to the printer, accessing the menu from control panel. Also verify if there is no label sticked on the media gap sensor.
Posted on Jun 03, 2014
SOURCE: Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Posted on Aug 04, 2008
SOURCE: Printer not calibrating correctly
Reset it to factory default.
Posted on May 21, 2009
seltzercool
  • 21 Answers
SOURCE: Zebra Z4Mplus won't calibrate 2" Circle Labels
try to set the printer to the factory default setting
Posted on Aug 20, 2009
  • 1121 Answers
SOURCE: My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Posted on Jan 13, 2010
  • 15 Answers
SOURCE: Stripe S600 Thermal Label Printer: how to load zebra stripe printer labels...
CLICK HERE to download the full user manual from Zebra. If the link doesn't work, go to Zebra.com, click Resource Library at the top of the screen, then click MANUAL. Choose your model number then follow the prompts.
Posted on Jun 07, 2010
My zebra z4mplus printer loads all the labels on the roll and when load the labels in the printer and turn the machine on. How can I make the printer stop loading after one label comes out?
May 08, 2014 | Zebra Z4Mplus Label Printer
My label starts printing halfway down the label
hi,
1. Check the printer settings of the software you are printing with.[most
probable cause]
cause]]
2. Turn off printer.
Open the printer and remove the labels roll.Re-load it and close the printer.
Press and hold the feed button.
Power on the printer and release button after first flash of led light.
Printer will self test.
Turn it off and on again.
Now print.
good luck!
Sep 09, 2011 | Zebra Z4Mplus Label Printer
My Zebra printer is eating labels on and off. I feel when the printer runs out of labels it losses the labels and never prints it again when the Labels are reloaded. Is there a configuration setup for the...
is possible calibration issues. please run manual calibration,
go through the setings and run MEDIA and RIBBON CALIBRATION.
if ask to load labels,
open printhead, take 2-4 labels from the back papel and load the back paper normaly.
then press enter. Ask for REMOVE RIBBON? open printhead and move the ribbon from left to the rigth of the printhead (remove from the sensors(left and side)) press enter.
let the printer save that figers from the sensors (back paper/no ribbon)
LOAD MEDIA?
ok, put all back on normaly (labels and ribbon set up proply) press enter.
The printer going to run the calibration, if stop on the gap?! save (press twice on SETUP Button.
SAVED? OK. turn of and turn on again, send the job.
Hope help. Rate please. Thanks.
Dec 17, 2010 | Zebra Z4Mplus Label Printer
Labels feeding incorrectly on Z4Mplus Zebra priner
Use this link and download the quick setup guide. Page 4 shows how to properly load the labels.
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
Aug 10, 2010 | Zebra Z4Mplus Label Printer
ZEBRA z4MPLUS LABEL PRINTER
Do Media and Ribbon Calibration . in printer parameters
Jun 29, 2010 | Zebra Z4Mplus Label Printer
I have a Zebra Z4M printer. Just put new roll of labels in and they print one, sometimes two and then skip labels in between.
This is a calibration issue. The labels or ribbon are not loaded correctly. If they are, turn the printer off and then back on and the printer will run a calibrate. This should correct it. Once it is complete, you can verify by pressing the feed button and making sure it feeds one label at a time.
Sep 08, 2009 | Zebra Z4M Printer
Aug 13, 2009 | Zebra Z4M Printer
During manual calibration of the Z4Mplus the
Let the printer calibrates itself or have a manual calibration in the printer setup. You can also press the keys FEED, PAUSE and CANCEL, turn on the printer and release the keys when feeding the labels.
Roberto Martinez
Jul 07, 2009 | Zebra Z4Mplus Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
Manual calibration of labels not working, printer not feeding labels correctly
printer manufacturers has different standards depending from the varieties of model and brand of printers for example an epson printer model who is older version is not the same speed print with the recent model likewise with the other brand. Therefore calibration of labels is depending to the version of the printer you are using now.
Apr 22, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
102 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
