Question about Home
We moved into a old trailer and the shower walls and tub have lots of mold and the shower when turned on on puts out a small flow if water like a drip weve tried replacing washers and shower heads but same result what could be the real problem
    Novelist:
    Champion:
  • 227 Answers
Older trailers had galvinized pipe in them. Over time galv pipe scales up and greatly restricts flow. Try pulling the stems and flushing out the valve body.
Posted on Aug 11, 2014
5 Suggested Answers
manhandy
  • 146 Answers
SOURCE: Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Posted on Jun 26, 2009
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
  • 102 Answers
SOURCE: I have a moen 1 knob push-pull faucet for my
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
Posted on May 14, 2010
  • 81 Answers
SOURCE: The water comes out of both the shower head and
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
Posted on Jun 02, 2010
Shower walls
You have got a lot of moisture behind your wall covering. Is that a plastic or fiberglass shower wall liner? You are going to have to tear out the shower walls, clean the studs, replace insulation and put in new walls. You must stop the leak too! You could be growing a lot of mold in the cavity behind your wall.
Jul 06, 2013 | Tools & Hardware - Others
The hot and cold are reversed on our single handle shower (no tub faucet -- shower only)
Hot on left.
Cold on right.
Some single handle faucets have bleed-over where both hot and cold enter mixing valve each time handle is turned on, even when faucet calls for just cold or just hot.
Otherwise maybe a do-it-yourself plumber got pipes backwards... or maybe the tub used to be on other side of wall, and tub was moved during remodeling but pipes were not changed.
To fix problem:
First of all, turn off shower faucet. Turn on Hot at sink and put ear against shower faucet listening for sound of water flowing through the mixing valve.
If mixing valve is working fine, you need to open wall and investigate more.
For example if you have access door, reach in and feel which pipe is hot.
Pipes might need to be reversed if problem comes up in home inspection, otherwise the problem will not harm anything.
Feb 19, 2011 | Price Pfister Plumbing
New installed no water flow?Water is flowing before and after the tub;so not a problem with valves or line???
If flow is slow to shower,pull showerhead,small watersaver hole and screen have garbage in it,teflon tape-rust sand etc Tub spout working fine?
Jan 28, 2011 | Danze Sheridan Tub & Shower Faucet
I a leak under my tub, think it's from the shower, it doesn't leak with a full tub of water or ewhen you empty the tub, but when you're in the shower a flow of water comes out under the shower piping side...
Check out the faucet plate mounted on tub side for a good seal. Water can leak down this plate causing it to look like the valve is leaking.
When you are in the shower it splash's water against the valve and water will run down behind it. Check the tub spout and if you have tile check the chaulked joint where tub and wall meet.
Jun 02, 2010 | Plumbing
Every time we use the shower there is a very pugnent smell [fishy] all drains been checked, all pluming been checked, all water is fine. shower is 11 years old could this be the problem. the shower we have...
Also check the following things:
The control unit, hose and shower head - depending on the type, some heads will hold water. Remove them and check to see if they are exhibiting signs of mold or possible failure. At 11 years old, the element could be on its way out. If your Mira unit has an auxiliary pump, it should be checked as well. If it's the shower head, you can try to soak it in white vinegar to remove the smell, or simply replace it. If you have well water, you should consider flushing the system to be sure water isn't being trapped somewhere. Also, if the iron content of the water is high, or if your water softener isn't operating properly, that could be an issue as well. The Mira control unit may need to be de-scaled or otherwise checked.
Check the shower stall walls (with no tub) at the bottom where they meet the basin, unless the shower enclosure is all one piece. There could be mold behind the intersection of the walls and base.
Look for any trace of mold growth around any other enclosure components.
If the shower is in a tub, remove the overflow cover on the tub and see if there is any trace of mildew or mold in that area. Follow your nose.
Finally, check for any excessive build up of soap scum, although this is less likely because you'd notice it more readily.
Things like this can be tough to diagnose, so just take things slow and one at a time.
Mar 08, 2010 | Home
I have an old home with a one hand Temptrol shower diverter which no longer regulates H2O temp properly. I purchased a Delta Carlisle 174939-SS-I and need to know how best to install this unit. I am a 60...
Start by turning the water off to the whole house. Open the tiled wall or if there is access behind the old valve open that wall instead. With a tubing cutter cut the hot and cold water lines as well as the shower riser. Remove any clips that are securing the valve to the wooden studs. Mount the new valve in the same area as the old. Make sure that the valve is not upside down arrows on the brass body will indicate flow direction for the tub spout. Connect the water supply lines to the new valve by means of soldering or mechanical joint. Connect the existing shower riser by means of soldering or mecnaical joint. Turn the water on and test for leaks.
Feb 09, 2010 | Delta & Single Handle Shower Faucet
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Home Logo
43 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
