Question about Vacuums
Changing a vaccum belt
How do you change the belt on a Dirt devil featherlite model m085540 manufactured in 2003?
  • Anonymous Feb 14, 2008
    where do i get the belt
  • Anonymous Sep 17, 2008
    The vacuum runs but the brush isn't turning. Is that the belt?
I have a problem putting a new belt on the hoover tempo upright U5140-900 vacuum.
I tried to get the manual
Posted on Feb 19, 2009
  • 1,673 Answers
Most of the Dirt Devils, turn the vac. over, remove the bottom plate, then you can get to the belt and brush roll. If the bottom plate doesn't come off, then from the top, there will be 2 or 3 screws to remove, then the top cover comes off to reveal the belt and brush roll.
Posted on Jan 29, 2008
No suction in vaccum cleaner
Look for a clog somehere in the intake path, perhaps right at the top of the canister.
Feb 13, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum not picking up.
check the bag it might be full if so replace for a new one check the belt it might be broken if you can see the fan sometimes there is some broken parts that have to be replaced
Jun 08, 2010 | Dirt Devil M085540 Featherlite Deluxe...
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
Dirt devil will not pick up
That means that you need to replace the belt. Here is the belt you need:
Dirt Devil FeatherLite Belt
Apr 06, 2010 | Dirt Devil Featherlite Bagless Vacuum...
I have a dirt devil featherlite plus and all of the sudden it started pushing hard and smells hot. I cleaned the roller, changed the bag, checked the belt. The belt is a little wore, but not bad.
If it is pushing hard then you still have a belt problem. It may not be broken but the belt is stretched out too long and will not turn the roller brush fast enough to make it push easy.
Nov 27, 2009 | Dirt Devil M085500 Featherlite Plus Bagged...
I need to change the belt
Here is a link to the belts you need and the manual which has instructions.
Dirt Devil Featherlite Belts
Download the Manual (PDF)
Nov 25, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Wont shut off when I press the power button
the switch has failed inside the unit so it is stuck in the on position
Oct 27, 2009 | Dirt Devil Featherlite Deluxe Bagged...
How do you replace the belt on the dirt devil feather lite vaccum.
not a expert just trying to help,,turn vaccum over take plate of and pull brush out and install new belt,,hope this help you
Oct 20, 2009 | Dirt Devil CE6100 Featherlite Upright...
Vacuums Logo
264 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
