Question about Baumatic Ovens
BAUMATIC OVEN OSF60
I have a baumatic fan oven the only number on the oven OSF60 I CANNOT FIND MY MANUAL AND HAVE GOT A PROBLEM COULD YOU HELP PLEASE THANK YOU. S SMITH
barkencoa
  • 3463 Answers
SOURCE: fan oven not heating up
If fan is working then the element has probably gone
Posted on Nov 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Posted on Jul 23, 2009
SOURCE: Baumatic built in oven (B600) product manual
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
Posted on Jul 27, 2009
  • 160 Answers
SOURCE: oven does not heat up in fan oven mode but fan
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
Posted on Dec 17, 2009
Testimonial: "Thanks, I thought it may be element but your advice allows me to go a buy the part I need with confidence."
We have just bought a Baumatic osf60 oven, but unable to locate a manual online. Help please
where did you buy it .I would try the manufacturer through their website if they have one
Jul 26, 2015 | Baumatic Ovens
I have just installed an Baumatic wall oven mod. no. B605MS.1. The clock has lit but the oven does not actually switch on and heat. Please help. Thank you
The electronic timer/clock must be in the manual mode for the oven to work. Consult your instruction booklet and set to manual. Your oven will then work.
Mar 07, 2011 | Baumatic Ovens
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Fan oven not heating up
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Ovens Logo
502 people viewed this question
Top Baumatic Ovens Experts
ashburton
Dennis Boxerman
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
