Question about LG LFX25960ST Stainless Steel French Door Refrigerator
How do you replacing fuse for a refrigerator
Replacing a fuse for this refrigerator
Why is my LG french door act like is has no power?
Probably a bad fuse on the main board. Fuse is not replaceable so either you have do a workaround (search LG refrigerator fuse repair for several fix videos and how-to's) or you have to replace the whole control board (part EBR41531302 I believe, but double check with your the part vendor before ordering).
Check the fuse by pulling the refrigerator out, unplugging, taking off back control board panel, and checking the fuse for continuity.
Aug 02, 2014 | LG LFC23760ST Side by Side Bottom Freezer...
Rm 2852 model refrigeration
MAY I KNOW THE EXACT MODEL/MAKER OF YOUR UNIT..?
THANKS
Jul 26, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
Fuse is blown in circit board
Did you have a power surge recently? That fuse can't blow itself. If a power surge got you then I would say to pull the board and put another fuse in. Of coarse unplug the refrigerator first. This may involve some soldering to remove the caps over the end of the fuse. If you did not experience a power surge then you should probably replace the board. If a component on the board has faulted, then replacing the fuse would be pointless. Because it would just blow it again. Hope this helps.
Mar 24, 2011 | LG 19.7 Cu. Ft. Side-by-Side Refrigerator...
My LG REFRIGERATOR stopped working all together, no lights, nothing is working at all. Checked the plug and it works fine.
ctmarrero was correct! There are two fuses on the mother board, and the larger one was blown. I took off the mother board (easy) and soldered off the old fuse and replaced it with a new fuse holder that will allow me to replace it next time without soldering. The fuse is a 250V 15A. This cost me less than $5. The new "PCB Assembly Main" EAP3533829" board cost $181.82 on easyappliance parts.com. Bad design by LG, should have had a fuse holder so it can be replaced easily.....
Oct 30, 2010 | LG LSC26905TT Side by Side Refrigerator
My refrigerator has stopped working, it is five years old. Could it be the fuse, where is the fuse?
it could be the fuse located in the back on the main board . the fuse is not replaced by itself . the main board is replaced as a complete unit . part is about 160.00 .. .. mm
Oct 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Just need to replace that 15 amp fuse on the circuit board.
most fuses on the board are only replaced with the board . I would use a after market fuse of the same rating . and if it blower it again find out why ... l g may not supply the fuse but any electronic supply should have it . mm
Sep 23, 2010 | LG LFC20760ST Stainless Steel Bottom...
Hi, My fuse is out on my refrigerator, 2008 model LFC20760ST. The fuse sits right on the circuit board and I'm not sure how to release it. Can you help?
the fuse is soderedto the board and is not to be replaced as a replacement part . but that doesn't mean that you cannot replace it . it may blow again and if so find out why . the board may be very costly and the fuse is not . so it's worth a try .. mm
No power to the side by side refrigerator
replacing the mother board is the option that a repair person uses if they are authorized on the back of the unit there is a square plate remove it and you will see the mother board. on the bottom right of the mother board is the culprit fuse. its soldered in. you will have to go to an electronic store and get another fuse and either replace it or have them replace it for you. i went to radio shack and picked up the fuse holder, soldered it in and in the future will only need to replace fuse.
Good luck..............
Jul 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Need to replace the fuse. I don't know where it locates.
No fuse on kenmore refrigerators is it dead no lights nothing?
Sep 23, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
13 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
